Tug;79417 said:
I really think you have low O2, your CO2 is what it is - yeast generate it. If you could increase your surface water flow this should increase the levels of Oxygen. Well then, the bubbler is a good idea. You might not need to run it all the time, but most of the night. Reduce your CO2 dosing at night, if you can (think Duetto).
We're going to be setting up the Duetto to diffuse the CO2 this weekend. So... I can simply turn the flow down on the Duetto to decrease the CO2 production at night? Won't I be risking an messy blow up of my 2 liter bottle?
Right now, I have a long bubble stone that is on a timer that turns on an hour before my lights go off and turns off an hour before my lights come on.
The way the spraybar of the Eheim is set up, it's several inches below the surface... I could probably rig something up to raise it up so it's disturbing the surface more... otherwise maybe I can see if my dad can follow the instructions re: making the Duetto a surface skimmer.
He's going to be visiting this weekend to help me with some projects.
What kind of yeast do you use nickel?
One teaspoon might get your culture up and running but using less, say 1/2 a teaspoon, would also work. It should become active just as quickly and last a bit longer.
I use Red Star active dry yeast... the kind in the little packets. I think I made a mistake in that when i opened the last packet, I left it sitting on the counter, open, and didn't put it in an airtight container in the fridge. I'm assuming that one is no good anymore and I should use a new packet with this next batch.
I was considering getting some vintners yeast instead... I heard that was better? The article I read said it is liquid and therefore more difficult to work with, but I found some on Amazon that's dry yeast and not terribly expensive.
http://www.amazon.com/dp/B003TOEEFG/?tag=barrreport-21
More sugar?
I think we both like sugar, but yeast can only use so much due to the build up of wast (ethanol). You don't need to add more sugar - try less. I could get away with using less my own self. Glucose —> Carbon dioxide + Alcohol + Energy
This is good to hear... as I was mixing up the last batch I was thinking to myself how expensive it could get using all that sugar for three tanks!
½ teaspoon of Baking Soda.
Baking soda is often added to a culture to keep it from crashing,
Yet a pH level of 5.5 would be considered fine for some yeast cultures using say, Baker's yeast. Again, less baking soda, maybe 1/8 tsp - just as helpful.
Okay, sounds good. My ph does lower considerably with CO2 injection. I got my GH and KH tests in: KH was 8 and GH was 4, but this was after the CO2 production had slowed down considerably.
Improve your water flow. Really, it is so important. Add a powerhead to increase the flow if you can.
I've never used a powerhead before... do they work to improve surface agitation? Or will just increasing the water flow do the trick?
Q. Is your yeast culture in water coming from your water softening unit?
Actually, all of the water (including tank water) is going through the softener. We're working on getting that fixed this weekend, too. We have to pick up the water storage containers (rubbermaid trash cans) and a pump, but likely can't afford one strong enough to get the water from downstairs (next to the 75g tank) all the way upstairs to the 26g (approximately 100 feet), so we'll likely just pick up a pump strong enough to get the water from the containers to the 75g, and when doing changes on the 26, we'll lug buckets up the stairs.
I suspect that a lot of my issues are due to the fact that the tank water contains water softened water, and hopefully things will be remedied soon.
Tug;79424 said:
For a longer lasting fermentation adjust the size container. Bigger container, same amount of yeast. Keep the buffer and sugar amounts proportional, more or less and get yourself a 2 gallon container.
I have a couple of 4 liter bottles. I will use those, instead. I was planning on using multiple bottles on this tank, but now am leery after seeing the fish struggle with just one bottle. Do you think it would be okay to set up one 4 liter bottle diffusing through a Duetto and one 4 liter bottle diffusing through the inline diffuser (the ISTA mix max)?
Thanks again for your help!
