Today I observed my blue ram breathing at the surface. My furcata rainbows often do this and i have chalked it up to CO2 intolerance. However, I have recently begun using an airstone at night to eliminate the white film that develops between water changes (works great by the way, no need for protein skimmer). Anyways, when I saw the ram breathing at the top I turned on the air stone, within 5 to 10 minutes fish behavior improved and the furcata rainbows were even more active. My pH meter didn't show any change in pH leading me to believe I did not air out much CO2, but rather improved O2 concentrations. My bubble rate was the same as the previous day and the ram did not behave this way. Water change was two days ago. Could O2 be depleting over time? My ram was much more active this evening after leaving the airstone on for a couple hours. pH changed by this point, but my CO2 had also turned off for most of that time.
What do people think? Is this too much CO2 or not enough O2? I see plenty of pearling during the day.
If it is O2, which I am suspecting, how do I increase my concentrations?
*wet/dry filter
*turn on the airstone periodically throughout the day?
Any other thoughts?
Thank you
*wet/dry filter
Any other thoughts?
Thank you
