Tom,
I just paid for a membership, so I wanted to post this here, I'm assuming you read this more then the free one.
Here is my dosing schedule
Dosing Schedule
Sun - No dosing
mon - 50% water change - 1/4 tsb K2SO4, 1/2 tsp GH booster, 1/4 tsb of KN03, 1/16 tsp KH2P04
tue - 1/16 tsb trace (kent, tropica, etc)
wed - 1/4 tsb of KN03, 1/16 tsp KH2P04
thur - 1/16 tsb trace (kent, tropica, etc)
fri - 1/4 tsb of KN03, 1/16 tsp KH2P04
sat -1/16 tsb trace (kent, tropica, etc)
As you can see I only dose KS204 on Monday's after my water change. I have read that people dose it 3x a week. Meaning I should also dose it on days I do my macro's. What do you guys guys think?
What would happen if I didn't have enough k2so4 in my tank? How do I know if I have enough, and what is it used for?
Any suggestions on my dosing?
it looks like I'm not getting enough "K'. What do you think?
Well I was doing the math, and I'm I'm doing my math right, I'm adding only 8.25 "k" into my tank once a week. (via K2SO4) Plus I am getting a very small amount of "K' from my KNO3. So if I am doing my math right, there is no way I am any where around the recommended level of 20ppm, thus meaning my plants aren't getting enough "k".
Also it looks like I am adding WAY to much kh2p04 into my tank. (IF I am doing the math right) it looks like I'm adding around 10-13 ppm of phosphate to my tank, when the suggested level is around 1.0 ppm.
which would cause issues in my tank.
thoughts?
Also it says that you use the "suggested" amounts if you have high light/high planted. If not use 50% - so I'm not sure if my tank is highly planted or not. SHould I use less ferts, more, change some things, etc.
HELP.
Dosing Schedule
Sun - No dosing
thoughts?
HELP.
