Tissue Cultured Plants Turning To Mush
Discussion in 'General Plant Topics' started by Dpstriper, Mar 5, 2019.
  1. Dpstriper
    Dpstriper New Member
    Mar 3, 2019
    10:41 PM
    First post so bear with me and thanks for any input.
    tank 9.2 gall with 8 lbs controsoil (extra fine) and maple rock.
    28 watt at 5 hours a day
    no c02
    aquaclear 20 on low flow
    Plants include rotala indica, java fern, dwarf hair grass mini, s repens, ar mini, ar cardinalis, hygrophila compactsl and hygro pin.
    20ppm nitrates, no nitrite, no ammonia, ph 6.6, 1dKH
    Some harlequin raspbora, some tetras, some pygmy Corys, some amano shrimp
    Tank is 5 weeks old and I'm finally adding 14 drops of flourish once a week.
    Most tissue cultured plants die and their roots turn to mush. What could this be due to? Only 1 week into using flourish. Any advanced tips for tissue cultured plants?
  2. cl3537
    cl3537 New Member
    Feb 20, 2019
    10:41 PM
    You have soft acidic water do you know why?
    Melting is often from Ammonia burn in uncycled aquariums but also from incompatible water to the plants you are trying to grow.
    How long ago did you add the plants?
    Those plants could benefit from KH (likely GH too) booster, ferts, and CO2 injection.
    Are you using API liquid kit or test strips?
    Dpstriper likes this.
  3. Dpstriper
    Mar 3, 2019
    10:41 PM
    Thanks for your reply, I use my tap water
    Testing with api liquid test and getting no ammonia.
    I have tried alkaline buffer but it raised my ph .2 and didnt have much of an affect on my kh. I plan on testing again. I would prefer just for my plants and fish to acclimate to my tap water.
    I added the ar minis when I first created the tank and they melted badly. I also added them again 2 weeks ago and they are melting too. It starts with small spots that turns into transparent leaves. This happens on the older and bigger leaves but the new smaller leaves seem to be ok.
    Again my tank is 9.2 g so I'm adding 16 drops, .8 ml, of flourish once a week. Is that enough? I'm going to try adding some seachem potassium too.
    I'm not ready for co2 yet
    I'm also increased my lighting to 6.5 hours a day. Should I go up to 8 hours this early in the life of the tank, its 6 weeks old now
  4. Kyalgae
    Kyalgae Lifetime Members
    Aug 25, 2016
    347
    234
    10:41 PM
    I almost lost all my tissue cultured plants to burn/melt. https://barrreport.com/threads/eye-of-the-shrimptigers-20g.14042/page-4#post-145409 I see your getting zero ammonia nitrite, but I would do some 90% water changes, it’s the only thing that helped my plants. You could add a little potassium (K2SO4). Perhaps the soil is releasing ammonia at the root level, but by the time it makes it into the water column the filter has already converted it? I caught mine too late and lost myriophyllum, but I managed to save the rest.
  5. Dpstriper
    Mar 3, 2019
    10:41 PM
    Kyalgae, great thread! Better read than any Grisham novel.
    i'm finally seeing some improvement this past week. I still lost all of my AR minis but the dwarf hair grass ecicularis is finally staying strong and even putting off some runners. I am now regularly dosing flourish comprehensive and added flourish potassium over the weekend; we'll see how this week progresses. Also, speaking with someone at my LFS they said to swap the charcoal in my aquaclear 20 for purigen as it wont remove the ferts (or at least significantly less from what i read on the internet). i'm hoping that helps as well.
    Also upped my light to 7 hours per day
    I think I finally hit a stable state with this tank but will wait another month before trying to AR minis again. i'll keep everyone updated.
    This pic is from a few days after the AR minis went in. They are completely gone now
    Kyalgae likes this.
