This Swag needle valve and how to set one up
AHura-sama
Mar 19, 2011
7
This one:
Does anyone know or recognize what model this is?? the seller doesnt mention anything so no help there. I went to Swag website to look up what could be It, but all the adapter terms got me rrly confused. So question, how do I set this up?? that is what are the necessary adapters and such. For the solenoid lets say the Burkert 6011.
The seller did mention it has a "1/4" VCR Nupro".
crowfoot
Mar 22, 2011
California
Looking through the Swagelok catalog, it looks like an "S" series metering valve which is their low flow model. It would help if the seller provided a model number. It's hard to tell from the photo, but I don't think that it's a VCR connection which uses a metal gasket to seal. It looks like there is an o-ring on the end of the connector, which would be a VCO connection.
If you're connecting to this metering valve to a Burkert solenoid, then you would need an adapter from the VCR or VCO connection to 1/8 male NPT.
I have a feeling that the adapter would cost a bit more, because VCR and VCO fittings are often used in high purity applications.
It'll work well if you get the adaptor to 1/8th MPT. Then you might as well buy a vernier handle as well.
bettatail
Apr 1, 2011
155
Did you buy the valve without knowing what are the cost of adapters?
you can almost pay for a same valve with the right connection ports for the cost of getting the correct adapters to NPT thread.
or, use expoxy, or solder.
AHura-sama
Mar 19, 2011
7
Ah, been a while
Someone told me the VCR is an odd connector so I didnt follow up w/ the valve. Someone BIN them shortly afterward, all 5 of them. Price was like 40 each.
Meh
