Hello,
I have been thinking about the current understanding of why BGA/cyanobacteria occurs and what to do about it. The current methods are to dose more nitrate, 3 day blackout, lots of water changes, cleaning, and/or medicate the tank to kill it, etc. It seems that often though, these methods are met with only limited success, and to be honest a blackout or medication of the tank to kill it seems extreme to me.
I have a hypothesis as to a possible cause. It is that a slightly anaerobic substrate might be the main or possibly only cause. Now I will explain why I am thinking this so I can get all of your input or correction.
It has been established that BGA can thrive in a low nitrate environment because it has the ability to use atmospheric nitrogen as nitrogen source, and the rest of algae and plants can't do that.
That always seemed off to me initially, because that (in my mind at the time), would only explain BGA growing at the water surface, not down in the water. I looked into it further and found that using atmospheric nitrogen doesn't mean that it needs nitrogen from the air, but more specifically that it can use N2, which is the form of nitrogen found in the atmosphere. N2 is also dissolved (in varied amounts) in aquarium water at all times, and that to me was a key to the puzzle.
What caught my eye a few days ago when I was reading about anaerobic substrates and anaerobic bacteria, was that the bacteria that live in anaerobic substrates actually use nitrate as their food source and give off N2 into the water as their byproduct.
You can have low (or no) measurable levels of nitrate in the aquarium water and still have varying levels of nitrate in the substrate.
If BGA doesn't particularly care about nitrate dosing you would think it shouldn't increase its' growth when nitrate is dosed, but when I tried just dosing extra nitrate to my tank to get the BGA to go away, it actually got worse. What if that increase in BGA growth had nothing to do with the nitrate itself and everything to do with the added nitrate then feeding a slightly anaerobic substrate bacteria more of what it wanted and then having more N2 put out into the water as a byproduct? The aquarium water N2 level might actually be what causes the BGA to begin/increase.
I was thinking about this, because if I dosed the extra nitrate right after a good gravel and tank cleaning (a cleaning of all possible anaerobic zones in the substrate) the BGA didn't really respond to the nitrate addition at all (or at least it was heavily delayed by at least a few days), but if I didn't do that cleaning first it would sometimes double or triple in mass within 24 hours. Could that be the true key to the cause of BGA and its' eradication, making sure the substrate stays as aerobic as possible to keep dissolved N2 as low as possible in the water? Now I give it to you all for your thoughts and experiences to see if they fit or refute my hypothesis.
This hypothesis would also explain how it is said that BGA thrives in poor circulation, but that people (of which I am one) can actually have a small BGA outbreak spot in an area of the tank that has great circulation and well aerated water. It is not the specific spot that is the key, it is the fact that somewhere in the tank anaerobic bacteria is adding extra N2 to the water and that is feeding it no matter where it is located.
As I have said before, I am just trying to figure this stuff out, and I don't know too much about it all yet, so if I am making a wrong assumption in anything I have said let me know. If anyone else has already mentioned this I apologize. I have not read or found anything like this online in my searches so far, but I could have easily missed it.
Have a good one, Jeremy
