The maximum CO2 amount
Discussion in 'CO2 Enrichment' started by Makram Monayer, Apr 30, 2013.
  1. Makram Monayer
    Makram Monayer Junior Poster
    Apr 20, 2013
    13
    2:32 PM
    Through reading some topics here in this forum I understood that when I use high light then I need much co2 and nutrients... my question is if the co2 is more than what is needed according to the light and nutrients did this harm the plants and what is the maximum ppm can plant stand? Notice that no fish in the tank
    Thanks a lot
  2. dutchy
    dutchy Plant Guru Team
    Jul 6, 2009
    2:32 PM
    You can not get CO2 high enough to harm plants. Most of the plants we use can also live emersed. The atmosferic CO2 is 350 ppm.
    Basically 40 to 50 ppm should be enough. The problem is that with very high light the CO2 demand of the plants is so high that we are not able to provide enough. This will lead to growth stagnation and algae.
    Fish will always be the limit. If you have to add so much CO2 that the fish get problems, the oly way to go is reduce the CO2 demand of the plants by using less light.
  3. Makram Monayer
    Apr 20, 2013
    13
    2:32 PM
    thank for replying me
    #3 Makram Monayer, Apr 30, 2013
  4. HD Blazingwolf
    HD Blazingwolf Junior Poster
    Mar 31, 2013
    10
    2:32 PM
    just curious. what is the light limit? i have around 100 PAR on the substrate and yet some of my plants curl their leaves and im injecting gobs and gobs of co2, i use a wet/dry to sustain higher oxygen levels.
    i feel like i keep lessening my light and growth keeps slowing down more and more as i do so yet some of them still curl, and some of my faster growign plants like ludwigia cuba aren't as large as they used to be, or colorful until they get closer to the light source, then they grow larger and more colorful and have no stressing.. and yet some of the plants that curl benefit when co2 is increased slightly, but then the nex day go right back to the way they are..
