The hard life of planted tank in Lebanon beirut
Discussion in 'Journals' started by Briceboke, Nov 20, 2017.
  1. VaughnH
    89
    2:41 PM
    How are you getting CO2 into the water? Do you run it through a ceramic disc diffuser in the aquarium? Do you use an in-line diffuser in the filter plumbing? What is the bubble rate for the CO2? How are you measuring how much CO2 you have in the aquarium water?
  2. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
    I found an atomic bomber but chinese it is really doing small bubbles compared to what I add before ceramic disk but poor quality...
    I do the kh/ph thing.
    The bubbles do not reach the surface before being moved all around
  3. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
    What is the best way to measure co2, knowing that I cannot get co2 checker, not available in my country
  4. VaughnH
    89
    2:41 PM
    I really like using a "drop checker" to measure CO2, but probably the best way to do it easily is to measure the pH of the tank water after the CO2 has been shut off for 12 hours or more. Then, turn on the CO2, and wait until almost when you are shutting if off again, and measure the pH again. The amount of CO2 you have in the water at that time is about 3 times 10 raised to the drop in pH power. For example, if the pH after the CO2 is off for a long time is 7.6, and the pH after the CO2 has been on all day is 6.8, you have about 3 times 10 raised to the 0.8 power(which is 6.3) or about 19 ppm of CO2. A pretty good CO2 concentration to try to get is 30 ppm, which corresponds to a 1.0 drop in pH.
    With this method, it doesn't matter what the KH is.
    burr740 and Mike k like this.
  5. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
    Ok great I will try that.
    Thanks a lot
  6. rs18alpha
    rs18alpha Subscriber
    Feb 3, 2017
    229
    24
    2:41 PM
    Sorry for not getting back to you for so long VaughnH, I will check the CO2 tomorrow before it goes on and then right before it goes off at night and I'll see what I get. I'll keep you posted.
  7. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
    Hi everyone it has been a while but here I am back.
    After so much troubles I am almost there.
    I am happy with my set up estimative index is working great and the change to a Co2 reactor changed my life.
    Here are some pictures tell me what you think.
  8. burr740
    burr740 Micros Spiller
    Staff Member Moderator
    Feb 16, 2015
    1,398
    1,168
    8:41 AM
    You are certainly making good progress, looks very nice
  9. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
    Update the growing is still great pearling is starting in a great way I have 1 plant that is growing but in a strange way and kind of look like it is drying!?
    Does anyone know what is the plant and if it should look like this?
    Thank you
    Phishless likes this.
  10. Phishless
    Phishless Lifetime Member
    Jul 13, 2017
    917
    859
    9:41 AM
    It is ammania (Nesaea) pedicellata or ammania golden.
    Re-naming has taken place here.
    It performs good in soil substrate.
    Golden brown colored tips with high PAR.
    EI ferts are fine but being a little wrinkled it wants more or less of something.
    burr740 likes this.
  11. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
    Some pearling and an uodate pic
  12. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
    Ok so to try to find what was wrong with the ammania I added some Epsom salt because I stoped for a few weeks not available in the pharmacies...
    After putting some in my tank, I don't know about the amania but the pearling went crazy!!!
    Plants I never saw pearling were bubbling insanely!!
    I have hard water but mostly Ca.
  13. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
    Hi everyone,
    So my ammania is getting weird...
    And my eleocharis is getting attacked by BBa..
    Any idea why?
    The rest is growing in a good way.
    Should I augm3nt the water flow?
    The 3 pictures are on the same area bottom left of the aquarium.
  14. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
    Hi could it be at water flow problem?
    But I am concern if I add a water pump I would have ti much current for my 18 gallons..
  15. Tim Harrison
    Tim Harrison Lifetime Member
    Jul 7, 2017
    281
    261
    2:41 PM
  16. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
    Hi everyone,
    Can you help me ID this algae and what should I do to reduce it.
    The tank in general is good but I fear it is on the verge of an algae blossom.
    I'm using EI,
    Dosage from Barr for a typical 20gal from the Ei article half Ro half tap water
    4 t5 lamp 24w each
    Thank you in advance
  17. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
    The full tank triming is coming for the plants in the back,
    By the way if anyone can id them that would be great
    DeepMetropolis and Tim Harrison like this.
  18. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
    Thanks a lot for the likes.
    Can I have a feedback on what to do with the algae,
    I am not sure what it is
  19. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
  20. Briceboke
    Briceboke Member
    Nov 5, 2017
    51
    4:41 PM
