The Custom Micro Mix Thread
Phishless
1,116
970
Arnold, MD
https://www.marinedepot.com/Hanna_I...uariums-Hanna_Instruments-HN1185-FITE-vi.html
All their units are $49
Not that I will test very often after this first week.
I compare it to not having a PAR meter and guessing about one's lighting.
Using capped soil makes things different for me than most.
Just trying to wrap things up in my mind about what the soil provides vs. what I am always adding in the way of ferts.
Reckon my capped soil will last quite a while since I also dose the water column.
Not really changing much water forces me to add ferts based on plant consumption per week without the accumulation that forces a massive water change.
I could never do this with lots of phish crapping things up.
Once per month I'm doing 15% WC's.
This is lowering my KH at a very slow rate, just how I wanted it to happen.
Now I am having to add GH booster to maintain a GH of 6.
Target KH is 1, I'm in the 3-4 range now so a few more months.
An improvement in plant growth @ a lower KH is showing with many species.
How much better will it be when I reach my target???
Reactions: Greggz
fablau
rotalabutterfly.com
Moderator
Sep 13, 2008
2,949
642
50
Laguna Niguel, CA
www.fablauplants.com
I have one of those colorimeters. The Fe one is pretty reliable, the Cu one not that much. A good tip when you take measurements, take 2 or 3 measurements, and then calculate the average. You will be surprised by how different results you can get...
Reactions: Phishless
Phishless
1,116
970
Arnold, MD
An Iron (Fe) colorimeter Update:
Periodic testing has been performed.
My normal dosing keeps about .38ppm in the water column.
Next day and several after it stays the same.
All of a sudden it drops to .08ppm in both capped soil tanks.o_O
Must be a threshold that Fe should be kept at that I haven't been in tune with yet! :rolleyes:
fablau
rotalabutterfly.com
Moderator
Sep 13, 2008
2,949
642
50
Laguna Niguel, CA
That's strange indeed... have you measured it again?
fablau
rotalabutterfly.com
Moderator
Sep 13, 2008
2,949
642
50
Laguna Niguel, CA
One question for everyone:
I have been trying to use an automatic dosing pump for the past month, and it has been very convenient for me. I dose 15ml of the micro mix solution in my 75gl tank daily, and it takes about 3 minutes to do it. I just dose macros manually, 3 times a week. The only problem that I have noticed by using the automatic dosing pump, is that the liquid in the bottle gets mold very easily. I used to keep the micro mix in the fridge when I dosed manually, but now, by using the automatic dosing pump, the bottle is just under the tank, not refrigerated, and mold develops after a few days I clean the bottle and add new liquid to it (despite I add 5ml vinegar to my 500ml solution, when I make it).
Any ideas how to prevent that damn mold?
Phishless
1,116
970
Arnold, MD
I've been dosing moldy micros for quite a few years!:D
I keep my bottles on the cool basement floor behind a tank to limit light exposure.
Allwissend
Super Moderator
Moderator
560
290
63
www.intuitiveaqua.net
Fablau, you can potassium sorbate and ascorbic acid to prevent mold formation. Vinegar is not very pure and has other organic molecules beside acetic acid... so better to go with more clean products like acetic acid, HCl or ascorbic acid .
Add the acid to reach a pH of 5.5 or lower. Add the potassium sorbate, 100ppm is reported as inhibitory for most fungi but many products may use up to 1000ppm. Too much in my opinion but gives you an idea. If this also fails you may need to also add sodium benzoate. Then add all the micros and check that pH is below the target .
Using solutions with mold is not the best idea as molds secrete powerful substances in the solutions, depends on species and final dilution if any effect is observed. Most impacted will be bacteria in any case. Nevertheless, molds consume some metals in the solution ... how much and what ... means a source of major uncertainty in your dosing.
fablau
rotalabutterfly.com
Moderator
Sep 13, 2008
2,949
642
50
Laguna Niguel, CA
Thanks for your reply. My bottle is actually in complete dark inside the tank's cabinet, so I don't think it is a light related issue... bit if you think that the mold inside the micro bottle won't affect anything, I could just keep the mold and stop worrying about it! :)
fablau
rotalabutterfly.com
Moderator
Sep 13, 2008
2,949
642
50
Laguna Niguel, CA
Thank you so much for all this info. Stupid question: Will those "preservatives" affect the micro mix in any way? Also: do you recommend using BOTH potassium sorbate and ascorbic acid together, or either one will be ok?
Thanks again very much ;)
Allwissend
Super Moderator
Moderator
560
290
63
Like Joe said, you would ideally want to use both as they serve different purposes.
The two will not interact directly with the fertilizers or the chelates to my knowledge. There are many studies done on the effects of these substances in fertilizers and foods... The majority conclude no damaging effects.
burr740
Micros Spiller
Moderator
Feb 16, 2015
1,398
1,300
Are you using potassium sorbate for both macro and micro mix? Any good store where I can get some?
You can find ascorbic acid and potassium sorbate on amazon or ebay.
Personally I have more of a mold issue with macros than micros. So I use K sorbate for macros too.
Clappies
Oct 17, 2017
South Africa
What do you guys think of this product? How does it compare to aquarium products? I dont know what chalet is used in it, but i dose when my co2 is on and ph is low.
Dose is 0.1ml on 250L tank, it seems very concentrated thats why i dont dose much.
Any comments will be appreciated
Thanx.
Sent from my VKY-L09 using Tapatalk
fablau
rotalabutterfly.com
Moderator
Sep 13, 2008
2,949
642
50
Laguna Niguel, CA
Wow, Cu concentration is crazy high! Be careful to use this stuff. What’s designed for? Golf lawns? I would no use it at all, even if you use it a tiny amount of it , it won’t do anything good (Fe/Mn ratio is also too wide). Not recommended in my opinion!
Clappies
Oct 17, 2017
South Africa
I think its used for a garden, i dont use it as my main source of Fe, i add fe gluconate with it. I also thought the cu is a bit on the high side... Mayne i can dilute it with a bit of distilled water when dosing?
I made a calculator for this stuff to see how much im dosing... But im not sure if my math is correct.
fablau
rotalabutterfly.com
Moderator
Sep 13, 2008
2,949
642
50
Laguna Niguel, CA
Well, yes, the problem is mostly the high concentration of Cu compared with the other elements. The problem is that if you lower the dosage to keep Cu within the "non-toxic" range (mostly for critters), the rest of the elements are probably going to be too low.
Also, if those are chelated elements, you may end up having similar issues we all have experienced with CSM and similar products (accumulation of some elements potentially interacting with other elements giving unexpected results, and more). Better to use non-chelated elements and have a balanced mix created just for planted tanks.
I hope this helps!
