Ok, this may get kind of long.
First, I assume that I am not the only one that has thought of this, so My 2nd assumption is that there are 1 or more fatal errors that make this impractical...
I use EI adapted to my own needs--not by the book. I currently do WCs every couple of weeks or so---and life is good. So, the Strict EI protocol is not being used here--including the weekly reset per 50% Weekly WCs.
I am wondering if the need for WCs can be determined by the build up of TDS's through TDS Monitoring?
Using RO water, then reconstituting it to desired levels, adding ferts and whatever else---Can a "Beginning" TDS reading be taken and the TDS's monitored to determine the build up and WC need?
I realize that there would be some fluctuation so a "Range" would be needed, but what are the fatal errors to this thought process?
