Hello All,
My tap water report from the city is as follows: This is Bangkok Tap, and I think most will agree that it is pretty good. With a Carbon block filter, and a .3 micron filter, I drink at least 3 liters of it a day(just as a side note) and what is listed below is only part of the report but all other params, are really clean.
Conductivity=μmho/cm,344
Total Alkalinity=95mg/l
Total Hardness=110mg/l
Carbonate Hardness=95mg/l
Non-Carbonate Hardness=15mg/l
Calcium=30.2mg/l
Magnesium=8.16mg/l
Nitrate as Nitrate=1.4mg/l
Ammonia as Nitrogen=.02mg/l
Silica=11.30mg/l
20 gallon, CO2 injected and heavily planted, auto dosed EI.
There are quite a few more results but I don't think they are relevant to my question, and some of the ones posted are probably not relevant. The reason I am posting is because I would like to know if it is necessary for me to use GH Booster?? I have made my own which I add 1.5 tsp every week with the aged water change water. My recipie is 200gr. K2SO4, 170 gr.CaSO4 and 120gr MgSo4, it's just a recipie I found on the internet. The main reason I am asking is because when I go to work in one of many armpits of the world for 1 to 2 months at a time, there are no water changes performed( girlfriend can't deal with it) and I was just wondering if the tap water I have could sustain the tank with Ca and mg until I exit the armpit and return to near the navel area
You may be asking yourself what I am doing now that makes it work, well, I am between jobs waiting for the next gig, so I am just adding GH booster to the water change water, but my leisure time is coming to an end soon(I hope)
. K2so4 and Magnesium I could incorporate into my KNo3 and PO4 Auot doser solution if it is necessary, but do ya all think it is necessary. And what about Calcium? Not so easy to get that into solution and keep it there for an auto doser, maybe time to try to find wonder shells or similiar here in the land of smiles
Just thought I would throw this up to you Guru,Expert, Einstien plant guys and see if I can find some joy. Thanks in advance for any help forwarded
Cheers,
Singtoh
Calcium=30.2mg/l
Magnesium=8.16mg/l
Silica=11.30mg/l
Cheers,
Singtoh
