T5 HO guide
Discussion in 'Lighting' started by soham, Feb 11, 2013.
  1. soham
    soham Junior Poster
    Dec 13, 2012
    19
    3:53 PM
    I went through Tom's recommendations on lighting and found out that too much lighting is the main cause of algae. I lowered my lighting intensity and found this to be absolutely true.
    Mine is 50 gal (3*1.5*1.5) tank with glosso, rotala, marsilea, hydrocotyle, arcuata etc. I have 4 39 watt osram 6500k lighting. Now i am using just two of them.
    Please let me know how many should i use? 2 or 3? I will supply enough co2 and proper EI daily
  2. dtang21
    dtang21 Junior Poster
    Oct 7, 2012
    26
    3:53 PM
    Gonna hit you with a bunch of questions first...
    What rate of growth are you looking for?
    How are your co2 levels in the tank?
    What brand fixture are you using (Are your reflectors good)?
    How far is the light from your substrate?
    How heavily is your tank planted?
    If you choose to run 2 bulbs, the demand for co2 will be less, you should encounter less algae, and it might be easier to find the balance point for your tank. If you want faster growth, you can run 3 bulbs. In both scenarios, I'd just play with the co2 and monitor the plant growth to see if its healthy.
