t5 fan hum deep blue
Discussion in 'Lighting' started by Mark Lem, Mar 20, 2012.
  1. Mark Lem
    Mark Lem Guru Class Expert
    Dec 4, 2006
    145
    3:50 PM
    I have a deep blue 36: light on a 57 and the fan hums, took end cap off, fan blades seem to sit on housing causing a hum. If i flip it upside down no hum...not sure if fixable any ideas
  2. DukeNJ
    DukeNJ Lifetime Charter Member
    Sep 18, 2009
    146
    3:50 PM
    I've replaced fans on fixtures by replacing them with computer case fans. Really simple to do. Can reduce noise quite a bit.
    You also may try a fan gasket. They are used to eliminate vibration and therefore noise from PC case fans. That might work too. They will add a little height so make sure you have the clearance.
