Hi guys,
Many thanks to those of you who have offered advise and expertise on these forums as I have read from many of you in exploring the world of planted aquariums. I have had reef tanks for over 15 years and I am looking for a change. In so doing I have decided to convert my reef tank to a planted tank. I have a bit of a plan formulating as I have poured over some of the threads here and was hoping to begin formulating my thoughts here in hopes of gaining feedback as i go so as to avoid major mistakes.
My current setup is a 1000gish display at 10' by 5' by 32" deep. Dual 2' overflows into a 300g remote sump. Lighting consists of 6 x MH (adjustable ballasts 250W-400W) and 8 x 54W T5 bulbs (currently actinic). Flow, in addition to return pumps (hammerheads) there are 6 tunze streams in the tank.
So below are my thoughts on lighting, substrate and CO2. Hopefully any glaring holes will be filled in by all of you and as I contine to research on the site.
I am thinking I would like areas of both high and low light. As I haven't totally decided on all types of plants yet I am thinking it would be nice to have areas of 250W and 400W giving me options as I go. I will need to change out to a lower K bulb it would appear. I currently run 12K and 14K bulbs, but the consensus is I will want to shoot lower. I have a few 10K XMs I might try unless even that would be too high. The T5s would be utilized for a dawn/dusk situation and color. So, I am considering alternating a pinkish red bulb with the actinics.
I'm wondering if there is a popular 6500k to 10k bulb most folks are happy with? Do you think the 400W will be too much even for highlight plants considering the lights are fixed at 10" above surface of water and 3ish " of substrate will be used?
Substrate: I think the only financially available option for this will be a soil mix of some sort. I was thinking about utilizing the method of soaking/drying/sifting and adding clay/sand wth some potash, then topping with a layer of sand (sand blasting sand probably). Probably run somewhere between 3-4" depending on scaping.
CO2: I have the cylinder/regulator from the reef system it would just be a matter of deciding how best to distribute this throughout the tank. I guess I havent' come across a good post of how quickly the CO2 degasses but most folks seem to feel you lose a lot of it pretty quickly?
This leaves me with several options. 1. run into my sump via atomic diffuser- easy and out of the way. 2 Run a separate pump in the tank with an atomic diffuser and postiion under a stream 3. drill a direct line into one of the return loc lines that has an eductor on the end of it 4. drill a CO2 line into one of the streams.
I haven't begun to narrow down plant selection yet as I am hoping I will be able to have low and high light areas. I'm not familiar enough with all the growth patterns of plants yet to be selective yet. Several pieces of driftwood for hardscape. I'm looking at a few pieces Tom has for sale here. As for fish I am imagining discus with a variety of smaller schools of tetras/danios/raspboras. Plecos and otos for cleaning crew with a type of shrimp. Corys on the bottom.
MY reef is still running as I am in the process of selling the livestock, so nothing is immediate, but I just want to plan well.
Thanks for any thoughts and critiques you may have.
Steve
Steve
