supplemented sustainable eco-aquarium
Discussion in 'Non-CO2 Methods' started by user name, Mar 28, 2014.
  1. user name
    user name Junior Poster
    Mar 25, 2014
    27
    3:36 AM
    Hello, first I would like to thank Mr. Barr and any other sponsors of this forum. It is unique, as most of the material is original in nature and excludes much of the redundancy that plagues internet forum discussion.
    Secondly, I would like to introduce my aquarium.
    75g semi- sustainable tropical ecosystem.
    Goals:
    Miniamal maintenance
    Highest possible biodiversity
    No water changes
    No feeding fish
    No replacing bulbs
    No dosing
    No co2
    Balanced flora and fauna
    Hardware:
    75G standard aquarium
    Sunsun 525 gph canister w/uv sterilizer stripped to floss only, spraybar set to aerate surface vigorously.
    2 beamswork 72x1w 10000k led 12/12 cycle
    1 marineland 2x18w gro light (to be replaced with comparable led)
    200w ehiem heater 78°f
    Tank contents:
    Deep dirted substrate, 1" limestone gravel, 2-4" miracle gro organic topsoil containing peat and wood fibre, approx 3 gal. Unsterilized natural topsoil containing clay from st louis mo backyard. Capped with 2" red pea gravel and 32lb black flourite sand.
    Split fon-du-lac limestone rock scape
    Flora and fauna description, as well as photos coming soon.
    Tank has been established for one month and doing well.
    Thank you!
  2. Tom Barr
    18,690
    706
    3:36 AM
    Dosing/and/or feeding fish will be required. You will have to bend on that one, period.
    Switch to dolomite instead of the limestone for the sediment, plain old clay loam from a clean stream would do best and keep it simple, Rice paddy, delta soil also will be best/better.
    Lots of shrimp, SAE's, plecos like Bushy nose of Sturisoma sp etc.
  3. Tom Barr
    18,690
    706
    3:36 AM
  4. user name
    Mar 25, 2014
    27
    3:36 AM
    Hear me out, I may supplement with mild dosing, but there will definitely not be any need for feeding.
    The crushed limestone gravel is already in the tank. Dolomite would be preferred, as it would release minerals more slowly. However the alkalinity of the limestone is countered with the acidity of the peat and wood fibre decomposing. Combined with the aeration af the water, th ph is stable at 7.3. Tap water in st. Louis is usually 7.8-8.2.
    Flora:
    hygrophila corymbosa var angustifolia
    Hygrophila polysperma
    Java fern
    Java moss
    Anubias barteri
    Narrow chain sword
    Ludwigia repens
    Fauna:
    Black worms
    Asian clams
    Daphnia
    Pond snails
    Trumpet snails
    Ghost shrimp
    Feeder guppies
    Otos
    Later to add 2f and 1m dwarf puffers
    So... here's the idea.
    Establish prolific colonies of micro life, allow algae to grow in limited quantities, and wait to introduce predators until long after breeding populations of all life in the aquarium have stabilized. Might 86 the ghost shrimp if they do not spawn. At any rate there will be shrimp of some vareity.
    The uv sterilizer is off.
    There are no clams, blackworms, or daphnia. They are coming soon. The light setup now has only one led fixture, but another is coming soon. More of a vareity of plants will be added later when the tank has matured.
    I consider a tank of this nature to have a minimum maturation time of 4-6mos.
    I am also entertaining the idea of inducing an algae bloom occasionally for filter feeders, then switching on the uv sterilizer if it gets to be too much.
    I'm using a samsung galaxy note and this format does not seem to allow me to upload pictures for now.
    Anyway what do you think?
  5. user name
    Mar 25, 2014
    27
    3:36 AM
