1) Can anybody tell me where I might buy ADA Aqua Soil and/or Seachem black flourite/sand in the Los Angeles area? My local store does not have either. (I can call around tomorrow, but just in case someone can save me some work... )
2) I am planning on starting out my foreground plants (HC, dwarf hairgrass and/or glossostigma) with the emersed method, in case that makes any difference on which substrate I use. Will either substrate work fine for this?
3) I've seen posts on this site about an ammonia spike (from substrate?) in the initial month or so. Is this bad for plants as well as fish? Since I am starting a new tank with all new equipment, I was planning on purchasing a bottle of "bio" starter to get my bacteria growing. I was also planning on having "plants only -- no fish" for about a month or so, just to be safe.
4) In case I have to order substrate online, I need help with quantity needed. I'm thinking about 3" of substrate in my 36x15x16 tank (480 sq. in. of tank bottom). I'm guessing that 2 of the 7Kg bags of flourite or 2 bags of the 9 liter ADA AS will be enough for this (some space will be used up with big rocks buried in the substrate). If the substrates "settle," perhaps I need more. Also, if it makes no difference, I wouldn't mind going with just 2" of substrate, since my tank is rather low in height (but I definitely will do what is better for the plants). I haven't even set up my first tank yet, and I already want a bigger one -- sheesh!
Thank you ... again.
