Making a stock solution is convenient as hell but i have read and observed at a friends place that it is hard to dissolve all the macro chemicals into one mixture!
Did some really brief reading and came up with the current mix thanx to a nutrient calculator
69.134g KNO3
12.151g KH2PO4
104.293g KCL
1) My question is would all the above macro ferts mix and dissolve in a 600 ml solution of distilled water?
i plan on adding 15ml of this solution to get npk ratio of 10:2:20 ppm.. and does this ratio work?
(been experiencing potassium deficiency so decided on adding kcl)
Does the npk ratio sound right ? i know there is no such ratio set in stone but have to start with somewhere!
2) Completely off topic - Does micro solution and macro solution (alternate day dosing ofc) form precipitates so much so that it causes deficiencies?
noticed a huge difference when i started dosing the micros only on one day (that is after the water change day)as opposed to every alternate day as per ei recommendations!
Sorry for the noob ques!
Thanks For your time people!
69.134g KNO3
12.151g KH2PO4
104.293g KCL
