Staurogyne Repens flat
Discussion in 'General Plant Topics' started by Oursaunougat, Nov 11, 2017.
  1. Oursaunougat
    Oursaunougat Member
    Nov 11, 2017
    80
    93
    8:09 PM
    hi all
    this is my first ask on the site, (i am french so not really good english speaking)
    I have allways liked this plant , but in my tank it is flat , the growing is on ground and extend on every sides but no take some high.
    What i can deduct from that ?
  2. skija
    skija Lifetime Members
    Nov 16, 2015
    262
    46
    7:09 PM
    Post 1-2 pictures , that can help
  3. VaughnH
    7:09 PM
    That is a low growing plant when you have high light. It only grows tall with lower light.
    Oursaunougat likes this.
  4. Oursaunougat
    Oursaunougat Member
    Nov 11, 2017
    80
    93
    8:09 PM
    Ok so just to much light for growing slowly taller
    We can see them on the right bottom picture (for answer to a pic request)
    Mike k likes this.
  5. Christophe
    Christophe Subscriber
    Oct 3, 2013
    374
    226
    7:09 PM
    If you trim staurogyne in place and leave the roots in, it will come back low and flat like that.
    If instead, you pull the whole plant roots and all, and cut stems of the best tops, 2-3 cm long stems. Throw away the roots, replant the top stems, they will grow taller.
    Oursaunougat and Mike k like this.
  6. Oursaunougat
    Oursaunougat Member
    Nov 11, 2017
    80
    93
    8:09 PM
    Good to know , Thankyou i will make some try
    Mike k likes this.
  7. skija
    Nov 16, 2015
    262
    46
    7:09 PM
    If the algae on staurogyne is BBA you have a co2 issue for sure , also it looks pale which leads to same issus , CO2
    Mike k likes this.
  8. Oursaunougat
    Oursaunougat Member
    Nov 11, 2017
    80
    93
    8:09 PM
    yes that is, and i have fixed to more by checking a real drop of 1 or 1.2 ph so wait and see if it come better
    Mike k likes this.
  9. ForTheHalibut
    ForTheHalibut Member
    Oct 12, 2017
    44
    10
    2:09 PM
    I want to make sure we understand your question. There are two reasons someone might want to grow taller staurogyne repens:
    1) Because they like the way taller staurogyne repens looks (pour l'esthétique).
    2) Because they want to grow more staurogyne repens for the purpose of propagation (pour la propagation).
    Which of these is your goal?
  10. Oursaunougat
    Oursaunougat Member
    Nov 11, 2017
    80
    93
    8:09 PM
    I would say for the look , cause the propagation is already fine ( 3 times the surface from beguin in less than one month)
