Stauro and Mc melt
Discussion in 'Are you new to aquatic plants? Start here' started by skija, Nov 17, 2015.
  1. skija
    skija Lifetime Members
    Nov 16, 2015
    352
    83
    2:39 PM
    Hi guys , i'm new to the forums , although i read barrreport for a year or so .
    I know there are a few issues related to plant melt but i want to ask your opinion here .
    Tank is 3 months old , 60 cm , Eheim 2071 , ADA AS , ADA Aquasky 7 hours per day , co2 3 bps , kh 3 , Ph around 6,8
    Plants MC , stauro , pinnatifida , anubias , buce , crypts and some fissidens moss.
    I dose Easy carbo (excell) daily and micros and macros every other day and 50 % water change .
    Plants started to grow well in the last month till theystart to melt , just MC and stauro , pinnatifida and anubias are doing fine .
    I couldn't get a clear picture of the plants but i found a picture on the internet and i can say mine looks 90 % the same
    Do you have any idea what is causing this ?
    Also in the red circle you can see that the stauro has a yellowish color , its not that clear green if you know what i mean
  2. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    2:39 PM
    Are you dosing too much excel or micros?
  3. skija
    Nov 16, 2015
    352
    83
    2:39 PM
    Well i dose Easy Carbo 2 ml , which is normal for 64 liter high planted tank and Fe i measured 0.2 ppm
    I know how plants look when i put easy carbo on the leaves , i touched one once when trying to treat local BBA , but this looks different .
    Also these plants are in the area where i didn't treat BBA so no easy carbo near them
    Here is a picture from my actual tank , you can see the stauro marked with red .
    Also as i mentioned my stauros are a bit yellowish if you can see in the picture
  4. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    2:39 PM
    The micros? Are you dosing too much?
  5. skija
    Nov 16, 2015
    352
    83
    2:39 PM
    My micro solution contains the following :
    Iron (Fe) - 2 g/l
    Manganese (Mn) - 1 g/l
    Copper (Cu) - 0,052 g/l
    Zinc (Zn) - 0,29 g/l
    Boron (B) - 0,4 g/l
    Molybdenum (Mo) - 0,075 g/l
    I dose 4-5 ml each other day
    as i said i'm measuring 0.2 ppm Fe right now
    you think its overdose of something ? not deficiency ?
    Thanks again
  6. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    2:39 PM
    It's probably a toxicity of one or more of the micronutrients. Those are very high concentrations relative to iron. Do a massive WC, 100% if possible, and then let it grow and dose when needed.
  7. skija
    Nov 16, 2015
    352
    83
    2:39 PM
    The only weird thing is that if i doze PO4 (from easy life) , after dozing i'm measuring PO4 1.8 - 2 ppm after 3 hours i dozed .
    The second day , aprox 24 hours later , PO4 its like 0.1 ppm
    Could it be the overdose of PO4 causing this melt ?
    I ordered KNO3 and KH2PO4 and i think will start using these next weekend after WC
  8. Pikez
    Pikez Rotala Killer!
    Staff Member Moderator
    May 12, 2013
    1,962
    1,470
    2:39 PM
    It's not the PO4. Do big water changes. Not a deficiency.
  9. skija
    Nov 16, 2015
    352
    83
    2:39 PM
    So you suggest to do water changes and stop dosing micro ?
  10. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    2:39 PM
    The PO4 may be attracted to the soil particles which means it's adsorbed onto it. It's still there but roots now have access to it. And no, phosphate will not cause melt.
  11. skija
    Nov 16, 2015
    352
    83
    2:39 PM
    Thanks again guys , i'll do the water changes and stop using old micro , i'we ordered chelated trace , KNO3 and KH2PO4
    Will do WC and use the new fertilezers , btw , i pruned the stauros and will see how they grow after i will change fertilezers
  12. skija
    Nov 16, 2015
    352
    83
    2:39 PM
    Hi guys , can you confirm that transparent leaves like this here http://www.barrreport.com/filedata/fetch?id=230754 is NO3 deficiency ? which indicates destroyed chlorophyll ?
    I started dosing KNO3 and KH2PO4 and Chelated Trace and plants started to grow again without having transparent leaves , was adding 15 ppm NO3 and 3 ppm PO4 . But after 2 weeks i see signs of transparent leaves again. Maybe plants grew and need more nutrients ? My tank is 60x36x30 cm and i use ada Aquasky 601 , CO2 starts 3 hours before light , and light is on for 6 hours. After aprox 1.5 hours after light is on plants start pearling
    Maybe the light is too much and i need to dose more NPK ?
    I forgot to say that the transparent leaves are also affected by pygmy growth , at least on monte carlo
    #12 skija, Dec 7, 2015
  13. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    2:39 PM
    N deficiency does not result in transparent leaves. Transparent leaves is a sign of metal toxicity. Cut back on trace elements.
  14. Pikez
    May 12, 2013
    1,962
    1,470
    2:39 PM
    It's not a nitrate deficiency. But if you are not convinced, add a little more NPK. No harm in that.
  15. skija
    Nov 16, 2015
    352
    83
    2:39 PM
    Ok noted , i will lower the micros , but i think could be N deficiency because MC has very small leaves on new growth , or im wrong ?
    Thanks again
  16. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    2:39 PM
    That's not a symptom of N deficiency. It's either a micronutrient deficiency or a toxicity, but considering that you are dosing a lot of micros, it's most likely a toxicity.
  17. skija
    Nov 16, 2015
    352
    83
    2:39 PM
    I dosed chelated trace yesterday around 18:00 , and when i measured Fe at 23:00 it was around 0.5-0.6 ppm , but i haven't measured the rest of micronutrients
  18. Dennis Singh
    Dennis Singh SynKing!
    May 5, 2013
    2,417
    639
    6:39 AM
  19. skija
    Nov 16, 2015
    352
    83
    2:39 PM
    I just find out what my chelated trace contains :
    Fe 8.2%
    Mn 1.82%
    Zn 1.16%
    B 1.05%
    Cu 0.23%
    Mo 0.15%
    I add one tsp to 500 ml water and i was dosing 10 or 15 ml in my 64 liter tank .
    Could be that this dosage of micros to create the toxicity to the plants ?
  20. Solcielo lawrencia
    Mar 20, 2013
    1,007
    43
    2:39 PM
