I believe somewhere on here I read that you can start a planted tank and avoid a cycle. Could someone explain this? Thanks
As it stands now I just have the tank which is a 25 gallon tank.
I plan to run CO2 and will use an eheim filter on the tank with the CO2 reactor plumbed inline. I am still reading more on ferts but I have some time. I would like to know what lighting would be good. Is a 70 watt metal halide enough or not and could I get away with something cheaper like say power compacts. What about T5's do they need individual reflectors or can I get away without them? I would like to keep it cheap but definately don't want to cut corners. I want to do it right the first time. I want to be able to keep pretty much any plant in this tank (not every plant but I just don't want to be restricted when buying plants).
Thanks in advance for the help.
-Tim.
-Tim.
