Started Dry Start Method
Discussion in 'General Plant Topics' started by david312, Aug 20, 2015.
  1. david312
    david312 Junior Poster
    Aug 20, 2015
    4:20 PM
    Hello,
    I have started a DSM tank.
    I would like to receive feedback from you guys, and if i'm doing it right..
    ill start with the tank description:
    its juwel rekord 700.
    Total 70 liters
    here its demensions: [​IMG]
    Lighting:
    I'm currently using the Juwel 15w Day-Lite T8.
    But i have ordered:
    Finnex Ray2 Aquarium LED Daylight - 24 inch. Should arrive in 9 days.
    The sub stare i choose is:
    base sub stare: Jbl ProScape Volcano Mineral.
    top sub stare: Jbl ProScape Plant Soil over.
    Here are pics of the set up, currently on day 3.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    I cover the top and leave a bit of air exchange space:
    [​IMG]
    I have couple of questions
    I have used tap water, is this okey?
    I have a tank low tech tank the i use EXCEL and Flourish in there, should i spray water from it on the plants?
    Should i spray them daily?
    I have a small water on a low point on the left, should i dry it?
    It would help if you guys would give me general tip/advice and feedback
    Thanks in advance!
  2. Solcielo lawrencia
    Mar 20, 2013
    1,007
    44
    4:20 PM
    Tap water OK.
    Do not add Excel.
    Flourish, if it's a fertilizer, yes.
    No need to spray if there are enough nutrients in the substrate.
    If there is ammonium from the soil, like ADA Aquasoil, then water prevents O2 which prevents NH4-NO3 conversion resulting in NH4 toxicity.
  3. bucky
    bucky Junior Poster
    Aug 6, 2015
    4:20 PM
    You may even want to take some water out. You'd be surprised how little you actually need, especially with the plastic wrap on top.
    A mistake I see people make (besides too much moisture) is putting driftwood in a DSM tank, especially driftwood that hasn't been soaked long enough. That is always a recipe for fungus.
    I have to say, that the whitest sand I've ever seen in an aquarium. What is that?
    #3 bucky, Aug 21, 2015
  4. david312
    Aug 20, 2015
    4:20 PM
