  1. Dismiss Notice
Stainless Steel CO2 Regulators (Victor SGT500, Matheson Ultraline, Parker IR6000)
Discussion in 'Trades, swaps, sales' started by alanle, Apr 5, 2015.
  1. alanle
    alanle Prolific Poster
    Jun 10, 2013
    210
    14
    3:11 PM
    If you like top of the line stainless steel CO2 systems, these are for you! How about CO2 system hunting for Easter?
    Victor SGT500 - This is a brand new 3rd generation (current) stainless steel SGT500 model from Victor. The system comes with dual Swagelok S Series metering valves. It is controlled by 2 separate miniature ASCO solenoids. This system is ideal for ramping up pH level or run in 2 different tanks with different time zone. This is the only 3rd generation SGT500 CO2 system with dual outputs, dual solenoids available!
    Price: $600 shipped
    Parker IR6000 - I built this system as a backup for my main system. I never had a chance to use it since my main system is a working horse. System comes with upgraded Wika liquid filled gauges, 200A Burkert Solenoid, Whitey 21 series angled metering valve (super hard to find), and Swagelok check valve. Complete stainless steel!
    Price: $485 shipped
    [​IMG]
    Parker IR6000 - This is another system that I recently built. It comes with a special Swagelok Kalrez stem metering valve and Burkert 6011 solenoid.I also upgraded a pair of liquid filled Wika gauges to match the status of this system. Complete stainless steel!
    Price: $495 shipped
    SOLD
    [​IMG]
    Matheson Ultraline 9400 Series - Here is a very special face seal (VCR) system. It offers the high purity of a metal- to-metal seal, providing leak-tight service from vacuum to positive pressure . This means the leak is measured at micron level! System comes with a Burkert 6011 solenoid and Swagelok S Series with vernier handle metering valve. You wont find another stainless steel system like this elsewhere but here! System is brand new.
    Price: $550 shipped!
    SOLD
    [​IMG]
    [​IMG]
    All systems come with CO2 tubing, power adapter and check valve.
    I also have brass regulators available. Use your imagine to design and I will build it for you. Price starting from $250.
    [​IMG]
    #1 alanle, Apr 5, 2015
  2. Monk
    Monk Junior Poster
    Feb 28, 2015
    23
    3:11 PM
    let me go sell some blood real quick! ;)
  3. alanle
    Jun 10, 2013
    210
    14
    3:11 PM
    I told Amano the same thing :)
  4. chris.rivera3
    chris.rivera3 Junior Poster
    Feb 1, 2009
    3:11 PM
    What's the purpose of liquid filled gauges? Are there any benefits and/or disadvantages?
  5. alanle
    Jun 10, 2013
    210
    14
    3:11 PM
    It's purely for aesthetic and cool factor for our purpose!
    Liquid-filled gauges are generally preferred over dry gauges for two reasons: performance and ROI. Liquid-filled gauges are filled with a liquid, usually glycerin or silicone oil and are designed to perform optimally in less-than-ideal conditions. While WIKAs liquid-filled gauges are engineered to function in difficult environments, theyre also more economical from a long-term perspective: High heat, pulsation, or vibration lead to instrument breakdown, but WIKAs liquid-filled gauges stand up to these harsh conditions.
    Liquid Filled vs. Traditional Gauges
    The primary reason for gauge failure is vibration. In traditional dry gauges, delicate links, pivots, and pinions are prone to damage from vibration, leading to inconsistent performance. In a liquid-filled gauge, the fluid fill effectively dampens system pulsation, making the gauge pointer easier to read.
    Likewise, humidity and moisture pose problems for dry gauges. Condensation can make a gauge difficult to read or, in some cases, can cause failure due to icing. Liquid-filled gauges, though, are sealed to prevent internal condensation, and by keeping moisture out of the system, gauge movement is protected during icing conditions.
    The choice of fill fluid is based on the application, but glycerin is typically used for room-temperature applications and silicone oil is commonly used for extreme temperature applications, especially when icing is a problem. An oil with insulating properties is ideal if the system has exposed electrical contacts.
    source: Wika
    #5 alanle, Apr 6, 2015
  6. alanle
    Jun 10, 2013
    210
    14
    3:11 PM
    Matheson Ultraline and the IR6000 with Kalrez systems are sold.
  7. Danny101
    Danny101 Junior Poster
    Apr 6, 2015
    3:11 PM
    Does the Victor SGt 500 come in brass to? if so, how much will it cost to get it build?
  8. alanle
    Jun 10, 2013
    210
    14
    3:11 PM
    Yes it would be the HPT500. I have one available, it has the same parts as this SGT500 (3rd generation). Please send me an pm and let me know how you want to get it built.
  9. Danny101
    Apr 6, 2015
    3:11 PM
    Humm? Great I have to have to 5 post before I can send a PM:( my email is kenny60714@yahoo.com can you send me your email thanks
