Spray bar for RIO 800 rvt
Discussion in 'CO2 Enrichment' started by inkslinger, Apr 28, 2011.
  1. inkslinger
    inkslinger Guru Class Expert
    Dec 15, 2007
    370
    1:27 AM
    Spray Bar for RIO 800 rvt is there one for this or is it a DIY what have others use?
    Is it possible to link the RIO to filter return spray bar if the return has larger powerful
    pump will the RIO be to weak to force the bubbles thru.
  2. Left C
    Left C Lifetime Members
    Sep 26, 2005
    2,510
    1:27 AM
    I rigged up the 600 RVT with a 12mm Eheim Spray Bar a few years back. It had decent power. The 800 may work better.
  3. inkslinger
    Dec 15, 2007
    370
    1:27 AM
    How did you add the Eheim spray bar to the rio pump?
  4. Left C
    Sep 26, 2005
    2,510
    1:27 AM
    I used some Eheim 12mm (1/2") parts. The OD of the RVT output is 1/2" if I am remembering right. Be sure to check it to see if it might be 5/8" instead. I used a series of 2 curved elbows and tubing to allow both the RVT and the spray bar to be attached to the aquarium's inside glass.
    I got all my parts from Big Al's at the time because they carried everything and they were the cheapest. Their picture of the curved line elbow shows a right angle elbow that you don't want to use. I don't know if their picture is wrong or what. Even when you search the part number 4014050, it shows the right angle elbow which is wrong. Anyway, I found the curved line elbow at ThatPetPlace.
    494 line elbow (Manufacturer Part #: 4014050): http://www.thatpetplace.com/pet/prod/211172/product.web
    494 spray bar: http://www.bigalsonline.com/Fish_Plumbing-Replacement-Parts_Canister-Filter-Replacement-Parts_Spray-Bar_9847041_82.html?tc=default
    494 spray bar pipe plug (end cap): http://www.bigalsonline.com/Fish_Plumbing-Replacement-Parts_Canister-Filter-Replacement-Parts_Spray-Bar-Pipe-Plug_9848833_82.html?tc=default or http://www.bigalsonline.com/Fish_Plumbing-Replacement-Parts_Canister-Filter-Replacement-Parts_Spray-Bar-Plugs_9847297_82.html?tc=default
    494 suction cups w/clips: http://www.bigalsonline.com/Fish_Plumbing-Replacement-Parts_Canister-Filter-Replacement-Parts_Suction-Cups-W-Clips_9998081_82.html?tc=default
    494 tubing: http://www.bigalsonline.com/Fish_Plumbing-Replacement-Parts_Canister-Filter-Replacement-Parts_Pre-Cut-Tubing.html?tc=default
    494 hose clamp: http://www.bigalsonline.com/Fish_Plumbing-Replacement-Parts_Canister-Filter-Replacement-Parts_Hose-Clamp_9981953_82.html?tc=default
    this 494 spray bar may work as well and it isn't green. Use can use the intake extensions if you drill out the places for the holes to increase the spray bar's length: http://www.bigalsonline.com/Fish_Plumbing-Replacement-Parts_Canister-Filter-Replacement-Parts_Spray-Bar-Set_9818625_82.html?tc=default
    intake extensions: http://www.bigalsonline.com/Fish_Plumbing-Replacement-Parts_Canister-Filter-Replacement-Parts_Intake-Extension-Kit_9810433_82.html?tc=default
    #4 Left C, May 7, 2011
