Spot Dosing
Discussion in 'Are you new to aquatic plants? Start here' started by steve todd, May 7, 2018.
  1. steve todd
    steve todd Member
    Dec 15, 2017
    80
    2:15 PM
    how much H202 do I need to use when I spot dose
    Cheers
  2. Allwissend
    Allwissend Article Editor
    Jun 20, 2016
    462
    266
    6:15 AM
    The dose necessary will be determined by time, concentration of the H2O2 solution, competitive reactants(other organics) and most importantly your target.
    In general in small quantities it is safe to add the H2O2 for about 5 minutes with the filter off to some spots. Stay below 0.045mL/L H2O2 (actual H2O2 not the solution volume) and it should be fine even for shrimps. I have to add that the dose required is highly dependent on how much mass and how much organics are available, ie moss in an aquarium may be unaffected by this conc. while moss in a sterile water vessel will turn brown. Look in my thread Algae..Journal ? for some documentation.
    But let's start from the beginning ...
    What are you trying to remove ?
  3. steve todd
    steve todd Member
    Dec 15, 2017
    80
    2:15 PM
    4BDF59A5-5546-488F-B231-0853B3957CF0.jpeg Having problem with this I. Brush it off within 2 days it’s back,using HH202. Seems complicated I’ll buy some easycarbo or excel
    #3 steve todd, May 7, 2018
  4. tiger15
    tiger15 Member
    Aug 12, 2017
    224
    77
    12:15 AM
    This is really bad! Can you take the fish out, hold them in a container, drain the tank, and spray with 3% peroxide from drug store. Wait 15 min, refill the tank and put back the fish. The bba will turn red and die off next day. To prevent return, correct the fundamental and dose 2x recommended excel dosage daily.
  5. Allwissend
    Jun 20, 2016
    462
    266
    6:15 AM
    There seems to be a great deal of debris on the algae. Consider repositioning your filter output to create better flow distribution and eliminating as much of that debris as possible via substrate vacuuming. Otherwise the algae you kill will just be replaced by new ones. High organics means more h202 or excel will be needed.
    Excel works as well but I prefer the clean leftovers from H2O2 (o2 and water), but your choice. If there are no plants in the area remove the water and spray directly on the rocks. If you can remove the rocks, treat it outside or bleach it.
    The problematic part is not the bba but the cladophora parts. This algae can survive mild conc of excel or h202 and only dies by the point that moss also dies. Plus, it tends to burry in wood like Fissidens moss, coming back when conditions are good. You have to really insist for this algae to go away
  6. steve todd
    steve todd Member
    Dec 15, 2017
    80
    2:15 PM
    what strength of bleach and how long to soak it,seems like the only way I’m going to get rid of it is strip tank down,
    Cheers
    #6 steve todd, May 8, 2018
