Since I'm multiplying questions on the forum on many posts, I began to discover that the all is turning around CO2 and light when we do EI. Sounds simple, but actually this CO2 stuff is killing me. So I chose to start this thread and continue here the debate instead of multiplying topics, hoping for a better overall advice/clarifications in my confused mind now.
I used to have a PH controller that I threw away once my faulty PH probe killed my snails, shrimps and one fish.
Since then, I was advised to focus on plants growth and a drop checker.
My tank looked like this first with EI:
Than, I was concerned by very fast growig rates and my Alternanthera reineckii aspect:
And my P. Helferi going to teh top despite intense light:
Two days ago, I followed the advices of some of the gurus here, I lowered my lighting from 4x54W T5 (10 hours) on my 40-60 gal to 2x54W at 12in height still with a 3h burst of 4x54W.
The problem is that since I begun focusin on CO2, I can't find a way to solve it
I invested in an AM 1000 inline with filter outlet. It runs fine and CO2 doesn't accumulate in the top. The outlet is directed from right side of tank to left side against front glass
I also have two 80gph recirculation pumps on the right. One of them is aimed to the surface and provokes slight water moves on surface, but really a few, no big waves at all.
Now my questions are:
- What about using this burst 3h period, should I completely forget it?
- My drop checker turns dark green quickely once CO2 is off by night and I need to start it 5h before light to get a lime green 2-3h after lights are on. How can I improve my CO2?
- I tried using a Nanostream Tunze 6055 pumpe. A powerhead type pump with output controlled from 1,000 to 5,500 l/h (264 to 1,453 USgal./h). The problem is that it makes a tornado even at 264gph in my heavily planted tank and plants really curve strongly. Also I fear the water surface movements provoqued will even worsen CO2 loose. How do you setup such pumps in a planted tank to avoid all this movement
Hopefully with lower lighting these issues will be solved in few days, but still wondering why my CO2 could take so much to act and how to use my Nanostream to replace my two small recirculation pumps
Many thanks for any advice on my issues.
really this CO2 thing is eating my brain
