Hello everyone and thank you for the opportunity to join in the group and learn way more than I already am familiar with. This post may be a tad long but I wanted to give you some insight to where I've been so that it explains my thought processes to what I'm currently involved in at the moment.
Real quickly, I've been into keep fish since the mid-70's. Just got involved with planted tanks in 2006 with my 55-gallon where I used the infamous dual 2-litre bottle approach and it worked splendidly!! My method of injection was simply to insert the tubing directly into the intake strainer on my Emperor 400 Biowheel filter. To add to the movement of the water I also added a H.O.T. Magnum Pro filter. I want to say again that this system worked awesomely! My yeast mixture was 1/8th teaspoon yeast to 1 cup sugar.
Now to the present. I'm at a point where I am working on one of my passionate goals. And that is to have a planted Discus tank. I understand that the main things to consider here is to focus on the fish first and their needs and then choose the plants that can thrive under the same temps and pH levels.
Some incidentals out of the way, I have a 72 gallon bowfront tank. I'm using only two 10,000K bulbs which should be suitable for the plants as using four would have been way too much light for the timid Discus. Even 2 is a tad bright but with the right plants and the addition of natural wood I feel I can tone things down a bit for them. I'm running these 10 hours a day. I'm also running 2 Emperor 400 Biowheel filters. The tank has been set up fish for about 3 months. I initially introduced 10 fry convicts until they reached about the 1 1/2" size and then I rehomed them. Once they were gone I started planting with what you see now. I also added some Seachem Flourish Potassium to help things along. My temperature stays a constant 86F.
I just tested my water and my ammonia and nitrites are at zero.
kH = 179ppm (10dKH)
pH = 8.0
As far as my general hardness I couldn't get an accurate reading. From the first drop to the 25th drop it just went from yellow to a darker yellow.
As you can see I'm sticking pretty much to the Amazons in the back for cover. The anubias and java moss to add character to the natural wood and I think soon when I get this CO2 thing sorted out some Red Melon Swords to add color. Later I'll tend to the front of the tank with some nice ground cover. By the way there is about 4" of Flourite substrate in the rear 2/3rds of the tank covered with gravel. The front of the tank has much less since the planting there will be much less.
Now to the main point of my post. The CO2 system. With all my previous knowledge albeit limited about CO2 I planned to do exactly the same as before with my 55-gallon BUT! I knew that I was dealing with more water and more plants so I upped the design and went with a canister in the form a new-in-the-box 1-Gallon Lawn and Garden sprayer. I figured it would be appropriately sealed and the one I chose would several times bigger than my previous setup.
I even stepped up the yeast by finding a local baker who is selling me live yeast at the rate of $3 for a one pound cube. This means I no longer have to activate it with tepid or warm water. It's ready to go right out of the package. I now have to admit I'm totally guessing on the yeast recipe. I'm dissolving 2 cups of sugar into just slight less than 70 degree water. Letting it cool slightly I then add 1 teaspoon of the live active yeast. I let this work for about a day and the best results I'm getting is one bubble about every 6-8 seconds and this seems inadequate to what it should and to what I need for this tank.
Am I correct in assuming I need to get my bubble count up there a bit? Would I be better served going with a diffuser and bell or is letting the filter do all the work efficient enough?
Lastly, I just want to state my goal and that is to reach a point with my plants as to not have continuously tremendous growth. By that I mean due to the Discus being such a skiddish breed I don't want to frequently be disrupting their environment with lots of gardening. I realize you cannot grow and not tend it and I loved grooming my plants before. For the sake of the fish I just want to keep it to a minimum.
Now I'm open to anything anyone would love to share and criticize.
Thanks so much for staying with this read so far and I thank you for your patience!
Have a most Blessed day!!!
~David
kH = 179ppm (10dKH)
pH = 8.0
~David
