Hi all,
I'm having a huge algae problem, with my tank infested with hair algae, thread algae and lots of BBA. I'm dosing the EI way, and I'm not sure if I'm doing it right. Below are some information of my tank:
Tank Dimensions (LxWxH, specify units): 2ftx1ftx1.5ft
Lighting Intensity(No of Watts) : 2 lightsets. Each 2x24w
Number and type of Lighting (FL/PL/MH) : T5HO
Age of light bulbs :New
No. of hours your lights are on : 9hours
CO2 Injection Rate (bps) : 2bps. Any more will cause an air pocket to build up in reactor.
Type of CO2 (DIY/Cylinder) : Cylinder
Method of Injection (e.g. Diffusor/Reactor) : Ista external reactor
Liquid fertilisers Used (Product name. E.g. Seachem Flourish) :
Seachem Flourish Nitrogen, KH2PO4 and K2SO4
Fertilization regime (Frequency and amount per dose) :
3 times a week Saturday (after WC), Monday, Wednesday
Seachem Flourish Nitrogen – 10ml --> 12ppm NO3
KH2PO4 – 0.02 teaspoon --> 1.42ppm PO4
K2SO4 – 0.3 teaspoon --> 22.34ppm K+
LushGro Micro (for traces) --> according to Label
Dilution
KH2PO4
0.02tsp needed
1tsp in 500ml 10ml 3X a week
K2SO4
0.3tsp needed
15tsp in 500ml 10ml 3X a week
Other additives (Product name. E.g. Seachem Prime) : Seachem Prime
Type of Filter (overhead/internal/canister, Product name/model if possible) : Canister, Eheim 2224
Filter media used : Eheim Substrate Pro and calcium rings and eheim sponge and wool
Age of setup (i.e. since initial setup or last major re-do ) : 2 weeks
Water change frequency : once a week
Amount changed : 50%
Water surface movement (None/gentle/turbulent) : Gentle
Circulation (None/gentle/turbulent) : Gentle
Tank Temperature : 25°C consistently
Bioload (Number and type of fish and plants)
Fauna:
~ 35 cardinal tetras
7 rummy nose tetras
2 balloon holland rams
2 threadfin rainbow fish
8 otocinclus
2 Siamese Algae Eater
1 Yamato shrimp
1 chinese algae eater
~5 snails (not sure what species they are)
As you can see, the algae problem is rather serious.
I've just dosed Amtra Algenmaster. But so far, there seems to be no effect.
Your help is greatly appreciated.
Dilution
KH2PO4
0.02tsp needed
K2SO4
0.3tsp needed
Fauna:
7 rummy nose tetras
8 otocinclus
1 Yamato shrimp
