If I could get some help, I would really appreciate it.
Info,
-46 Bowfront
-Co2 is GLA pressure with bubble counter (4bps) into large inline reactor (2 1/2in by 16in long)
-Drop checker reads lime green
-Digital 300 watt heater set to 76.5 and my regular thermometer reads the same.
-filters, 2217 and a 2215 with no carbon and I just cleaned them both 3 weeks apart from one another
-Full EI dosing
-Lighting, T-5 NO 1.8 watts, I cut the light down to .91 for a week and it made only a small difference for the better.
Plants,
Ludwigia Glandulosa
Ludwigia Repens
Crypts, green and brown
Java Moss
Java Fern
The plants are all growing, however the Glandulosa’s leaves have recently started twisting at the tips, the Java Moss has a strange looking very short white hair algae growing on it and I’m getting some (what looks like) brown algae on all the lower leaves of everything and on the glass. Every time I do a water change the water gets slightly cloudy for about 4 hours or so and then clears. I have surface scum that comes back after I clear it in just a few hours, otherwise the water is pretty clean and clear.
Picture of surface scum in bottle that I siphoned it off the surface with; I clear it every day when I dose. If you look at the water in the tank you can see it’s quite clear.
Tank,
Info,
-46 Bowfront
-Full EI dosing
Plants,
Ludwigia Glandulosa
Ludwigia Repens
Java Moss
Java Fern
Tank,
