Sorry, double posted, first one is in the wrong forum...
I need a little help in trying to determine what I need to adjust to get my tank running like it should. Everything seems to be growing fine except the foreground plants.
Specs:
155 bow front
Temp: 76, cable heat
Lights: 2 aquamedic sunbeams 80watt T5HO, 320 watts total. 10hrs/day. 35 inches from substrate.
EI dosing:
2 tsp KNO3 M,W,F
1/2 tsp KH2PO4 T,T,S
2 tsp G4 Boost SU with 50-60% water change
1/2 tsp CSM-B M,W,F
Filters - Fx5 with inline CO2 reactor, Mag 350 with Ehiem surface skimmer on a split input line.
4 koralia #1 (4x400g/hr) (circulation seems fine everywhere)
Drop checkers running yellow to yellow green
Water is ro/di & tap 75/25
I bought a quantum sensor and did some par readings:
Drop checkers are running yellow 2 hours into light cycle. CO2 comes on 2 hrs b4 lights, off 30 min b4 lights out.
Lights are spaced 6 inches apart for good spread:
The problem is the foreground plants are not growing well, I had an issue with diatoms a few weeks ago but they seems to be clearing up, new growth on the plants, but still some browning on the outside edges:
The Glossostigma is growing straight up like it is reaching for light
Could this be some deficiency of some sort? Not enough light? More CO2?
Thanks in advance,
~Dutch
Specs:
155 bow front
EI dosing:
2 tsp KNO3 M,W,F
1/2 tsp CSM-B M,W,F
Thanks in advance,
~Dutch
