So I Stuffed Up... Ada Amazonia Soil
Discussion in 'Sediment / Substrate' started by 7smurfs, Oct 13, 2019.
  1. 7smurfs
    7smurfs New Member
    Oct 13, 2019
    6:26 AM
    Long story short.
    Re-running this tank that had 1.5 years of ADA Amazonia in it.
    I cleaned out the tank and out of habit from my goldfish keeping days, rinsed the soil only to find out after you’re not supposed to.
    Now do I...
    Add another layer of Amazonia on top
    Scrap the entire 5 bags of Amazonia and buy the soil again. Hard lesson learnt
    Just keep doing 80% water changes til it clears up.
    I've thus far done, a 100% water change as I had thought I may have filled tank too quickly.
    Had the filter on for 24hrs however have now switched it off. Should I be keeping the filter on?
    Any help for this noob would be much appreciated!
  2. Irenical
    Irenical New Member
    Oct 16, 2019
    3:26 PM
    I'd wait like a day or two with the filters off and let all the suspended substrate precipitate.
    I guess you could keep doing water changes but isnt that almost like rinsing it.
    Also keeping the filter on would just gunk up it up so you'd have to clean that up anyway.
    If your not pressed for time, doing nothing is what I would do.
    Sent from my SM-N960U using Tapatalk
  3. rajkm
    rajkm Article Editor
    Sep 16, 2015
    670
    216
    9:26 PM
    Just do 2 back to back water changes. You should be fine.
