Snails..
Discussion in 'General Plant Topics' started by zchauvin, Jul 9, 2018.
  1. zchauvin
    zchauvin Member
    Jul 8, 2018
    34
    10:35 PM
    So my tank is about two months old. I added some plants and ended up buying from a hobbyist and have more snails than anything else now. I'm going to completely take apart the tank, clean it out and throw all substrate. My question is when it comes to my filtration.
    Should I clean it in water/bleach or let it dry out and start from scratch, or should I be ok to keep it running. My worry is snails or eggs that would have contaminated the filter media.
    Sent from my SM-N950U using Tapatalk
  2. LRJ
    LRJ Subscriber
    Aug 11, 2014
    102
    54
    11:35 PM
    When I clean my filters, there are usually some snails that have made it into the media. I imagine this is pretty common, so to completely get of them, I imagine you will need to clean the filter too. But, that's a lot of effort to get rid of some snails. Is there a particular reason you don't want them? Many hobbyists like having them in the tank. You might want to consider just letting them stay. If they're overpopulating, there's likely an excess food supply, and that can be controlled.
  3. zchauvin
    zchauvin Member
    Jul 8, 2018
    34
    10:35 PM
    Thanks, I figured this would be the case. I really just dont like them and dont want them in my tank. When cleaning media to kill off any snails, what is the best option?
  4. Allwissend
    Allwissend Article Editor
    Jun 20, 2016
    498
    275
    5:35 AM
    H2O2 (wear gloves at least) or just dry out for long periods of time. In my opinion you can also get rid of snails if you get some assassin snails combined with active crushing of any you see. High levels of CO2 and soft water ( low KH) will also kill them in time.
  5. zchauvin
    zchauvin Member
    Jul 8, 2018
    34
    10:35 PM
    Thank you, I try to remove what I can manually and do have high co2 with pure RO/DI and amazonia so soft water. It started with only very few smaller ones now I see one or two larger here and there. Not a ton by any means but I just dont like them.
