Slow deformed growth, and brittle plants....
colonel
Nov 25, 2005
118
Re: Slow deformed growth, and brittle plants....
Aquaman just curious with around 45 ppm of calcium in my water why do you think that this is the nutrient that is missing in my tank? Im not trying to say your wrong.... I just dont understand why you think that.... how much is enough then if 45 ppm isnt? Also you said...
Schultz aquatic plant medium is mostly an illite clay which is very good for
storing cations which the mineral picks up from its environment in small quantities. The use as a substrate is more appropriate outdoors where you have external inputs such as wind blown dust and organic matter. This substrate is probably defficient in Ca unless it was calcined in the manufacturing process. It is definitely nowhere equivalent to Flourite in iron content. For a flourite substitute, Turface Pro is probably a better choice for both iron and calcium.
In earlier post i NEVER said that I used this as a Flourite substitute.... rather explained it in PHYSICAL chara. SIMILAR to flourite. and as far as it being defficient in Ca... it was my understanding that in aquatics, Plants generally perfer not to have a high concentration of Ca in the substrate?
I dont really know... I do appriciate your insight... how ever I dont really see how this directly has any affect on why the plants are not doing so well.... other than if you think that the nutrients have precipitated into the substrate and raised to toxic levels there. However even so.... seems as though the levels of nutrients I am adding just arnt high enough anywhere substrate or not... to cause problems? as Tom as listed many times doing expierments with different nutrients at high concentrations.... much high than in my tank with no ill effects.
Since we now know that Ca was the nutrient in short supply
Back to this.... I still really dont understand why we know that Ca is in short supply.... I just dont see it? maybe you could explain that one better to me and others.....
thanks for the input
colonel
Nov 25, 2005
118
Just a Quick question for Tom, or anyone else who would like to chime in here.
Over the weekend I did a large 75% WC to reset the tank, and as I mentioned before NO baking soda any more.... going to leave the KH low at an attempt to save the little bit of Tonina I have left in there.
Any way over the weeking I have also been bumping up the CO2. I just tested tonight and my PH reads 5.9 that is down .3 from the 6.2 before I started adding more CO2, and my KH is at 3.5. Looking at the chart which in my case for whatever reason I know cant be right.... or for whatever reason Im getting testing errors some where. I would have 132 ppm CO2.
My question is should I keep adding more CO2 to the point that the fish react? or should I go with easy does it and leave things here? Basically today there has been a lot more pearling in the tank than usual.... and for the most part the fish have not seemed to be disturbed much. No gasping at the surface, and they really dont look stressed other than some faint colors in a few SAE's which could also have been due to the change in PH since I notice this when I change water with them. Any way everyone seems to be doing well with it.... So shall I keep it there? or go even Higher with the CO2? any advice would be appriciated thank you all :)
Matt
18,696
745
You actually can have virtually no KH or even none. But you need to be careful and add the CO2 prior to lowering and look at the plants for more a "feel" of what good CO2 looks like without gassing the fish.
Well, for all the rants over PPS and other test, we have seen many folks really have serious doubts over their KH/pH/CO2 readings.
This is a general problem many have.
I've always used my eyes and the fish health as the ruler, then measurement is secondary and relative to these two parameters(Fish and plant health).
Matt
Well, if you get pearling relative soon, by midday at least, then you are likely in good shape.
You can monkey with it and tweak it a little further, but careful.
If things look good, that was your orginal goal to start with.
Tweak later is you cannot help but fiddle, just be delibrate and careful when messing with unknown measurements.
Use the bubble rate etc, or the fish and you'll need to be around most of the day while the CO2 is being added to make sure.
18,696
745
Jamie already tested this way back many years ago and flourite and a dozen other soils etc.
Aquaman said:
Plants will definitely grow twisted if you are calcium limited.
And you have seen this in submersed aquatic plants?
Photo's? I've seen about a dozen different things that can cause this same trait. It's hardly a definitive Calicum relatable issue.
Most of the advice is based on terrestrial plants.
Try boosting your KH with powdered CaCO3 instead sodium bicarb.
But KH does not play a role in plants, the Ca is the issue he's trying to rule out, easy enough, add some Gh builder, Seachem EQ, CaCl2, CaSO4 etc.
But I do not think this is the issue.
For vascular aquatic plants it is important to transport O2 down to the root zone at night for many complex reasons having to do with nutrient scavenging and use processes. Some plants that do not have leaves at the surface or emergent have trouble if the substrate is too acidic or too low in oxygen.
So why do we have plants without leaves at the surface then?
Why would it be any more important at night versus the day?
All water lilies do this only during the day(pressurized ventiliation).
Respiration is 24/7 process, it's not all done at night or during the day.
There is scant evidence for submersed gas transport to the substrate but most do do it, but it's a 24/7 process near as anyone can tell.
First, if you are using a cannister filter which gets changed infrequently(such as an Eheim), as the filter loads it becomes the largest biological oxygen demand on the aquarium system. At night when the plants are no longer using CO2 and producing O2, they become oxygen users along with the fish and the microbes in the filter and substrate.
I agree that fish and bacteria at the main issue, but you will kill every single fish before a plant becomes deprived due to low O2.
Don't worry, after PO4 this month, there will be one on Oxygen for Feb.
Seems like it's need here lately.
Short of profiling the O2 diurnal cycle every so often,
I've done this more than you wanna know.
you cannot be sure that you are not depriving your fish and/or your plants of needed O2.
Well you certainly do NOT need to do a O2 profile over time.
You can simply watch the fish health, behavior(although it's a bit mean, but we enslave the fish to begin with as our pets/prisoners etc) to see if the O2 is too low or not.
Add some surface movement instead of night time aeration, I'm not sure why so many folks have troubles and leave the surface totally still in efforts to conserve CO2, you are going to lose some either way, but you should not reduce the surface to the degree it hurts the fish health.
Folks worry too much about wasting CO2 that way and not enough about having good O2 over the entire 24 hour peroid.
This is hardly new, folks have had this same issues for many decades.
I've used night aeration in the past but never found anything significant.
Every tank I've done in the last decade does not use night time aeration and I have higher fish loading in many of the tank most anyone I've met.
Although fish can live through a period of reduced DO, they may not be able to thrive if BOD becomes too high which has ramifications for long term husbandry all other things being equal.
So simply tending the tank and removing dead leaves, mulm, once a year vacuuming excess mulm out of the tank and weekly water changes deals with BOD easily.
Obviously with a light fish load and a spray bar return you are at less risk. Since fish easily double their O2 need while digesting food, I would not recommend feeding at night just before the lights go out and there is no aeration.
Well, I've never had an issue there.
But you are right about the drain on O2, but that assumes that there is an issue with that to begin with, simply adding some current from the spray bar will solve any of this.
A word about CO2 and O2. The concentration of these dissolved gases is independent. It is possible for both gases to be saturated.
Well, I know what you are trying to say, but CO2 fully saturated?
You probably do not wanna go there:)
Excess CO2 for a given KH/pH will still cause fish death by anesthesia in the presence of saturated DO. It is also possible to have supersaturation of all the gases and fish death by gas embolism. See the concepts of Total Gas Pressure and Partial Gas Pressure.
Yep. But with good O2, things are much less an issue.
We can always add a bit more CO2, so it's loss while minimized ideally, is less important to the fish and bacteria.
I simply do not add CO2 at night to start with, then the fish if they are exposued to high levels of CO2, it's only for a few hours late in the day in conjuction with super staturated O2 levels.
As the CO2 off gases at night, so does the O2.
The explanation for the comment of your additions of nutrients outstripping the useage of those nutrients by the limited growth plants assumes that CO2 is not the limiting factor.
And that is where he should start.
Most any problem with plants if CO2 is used, should always include a thorough check and then add some extra anyway just in case but also keep good tabs on the fish.
Also some nutrients become inhibitors if their concentration gets too high.
Such as and how high?
I've looked quite a bit for a very long time, it's going to be extremely tough to show what these levels are and for which plants in our tanks.
I know of no high PO4 level, shrimp and fish will die before the NO3 causes issues, 100ppm + K+, only caused one person to win a competion in the AGA contest. I've added 200mls of Flourish to a 20 gallon tank. The water was coffee colored for 4 days.
GH has been as a high 24 degrees.
It's much easier to find limiting ranges and levels.
I've search some for the upper ranges, but they are very high before negative issues come into play specifically with our planted tanks.
So high that if you do water changes routinely, there is little need to test.
To illustrate, you were adding K, Mg, sulfate, and nitrate but you had brittle stunted plants with limited growth. Since we now know that Ca was the nutrient in short supply within a few days after a water change, your rate of addition of the other nutrients was exceeding the rate of uptake by the slow growing plants. Thus concentrations in the water column were rising. This is why your TDS(Total Dissolved Solids] and indirectly your GH were rising. They were not being removed from the water column by plants growing. Remember, plants are used as filters in environmental science. GH is effectively cation hardness.
Hope this helps.
But you are assuming the CO2, which does defintiely produces the these traits in new growth, is not an issue.
I use soft water and have for a number of years as well as hard water as I've moved around the country. While Ca can easily be ruled out, dosing a little once a week etc, the CO2 is quite another matter.
Still, both the CO2 and the Ca can be addressed and both will solve the issue.
I can go back and have the aquarist test if they really wish to figure out which is which, but most simply want the problem fixed and move on.
Given the amount of % of the issues I've fielded, CO2 is most of this if I were to bet. It's rare that we see Ca deficiencies, even with soft water.
I've not seen toxic trace build up ever in planted tanks with any substrate. I have see too much organic matter + a little SO4-> H2S but even that is rare and most often when someone adds a rottening Apono bulb etc into the gravel, or uses non preconditioned soil.
Aquaman
Mar 20, 2005
Colonel,
My bad. I stand corrected about my statement that your tank is calcium limited. I did not realize that you are doing weekly 75% water changes.
Given the water changing regimen, other questions are raised. I think your pH reading or your KH reading is way off. Check that meter with standard solutions(availabe in cheap packets from all the usual suspects) or use a bromothymol blue test to double check your readings. Test strips seem to only give accurate ph readings in high KH water. Secondly, if your KH is 100ppm, you are driving the pH down to 5.9, and you have slow growth, then how did you not anesthetize your fish? Also, why is the GH rising so dramatically in just a week? Is the substrate CaCO3 rich? Is excess CO2 going to carbonic acid and liberating enough Ca to act as a growth inhibitor? This would explain the rise in both GH and KH. There is a good discussion of these relationships at the Miss. State web site for the Southern Regional Aquaculture Conference (SRAC Publication Fact Sheet # 464) titled Interactions of pH, Carbon Dioxide, Alkalinity, and Hardness in Fish Ponds.
Tom points out in his reply that Ca deficiency is not the only cause of twisted
growth. In checking my notes of the several times I have seen this. Only once
was it solved by adding only Ca. Several other times(with sword plants only) it was solved by adding Seachem Equilibrium which has lots of other stuff as well as calcium. Two other cases were interesting. They occured with tanks that had auto water changing regimens of 10% per day and a tap water GH of 130ppm, KH of 80ppm, and ph of 7.8. The solution in both cases was to set the CO2 supply to drive the ph to 6.9 in the tank. Then the plants took off again.
Also, I noticed you just increased your lighting substantially and are now seeing pearling. Your slow growth might have also been due to old lamps with a greatly diminished PAR output. If you had compact florescents or cheap lamps(low grade phosphors or thin coating), after a year the output of the lamps had dropped way off and you had not adjusted your additions for a lower energy input situation. I have also seen that result in problematic growth for some species.
My education is in geochemistry and fish husbandry engineering and I work as an aquarist and exhibit designer. I come at this plant business from the fish side of things whereas Tom comes at it from the plant side. I currently have over 100 species of aquatic plants under care. Not only are they a beautiful addition to any display but they clearly enhance fish vigor, behavioral well being, and overall health. Having said that, I am much more careful about CO2 than some of these plant people are. For this and other reasons, I do not recommend running your pH below 6.6-6.8. In long term husbandry of fishes, there are many issues connected with captive husbandry of fishes in low pH water. In addition, I use the CO2, alkalinity, pH chart religiously and have not found a need to raise CO2 levels higher than the "safe zone."
On another vein is your tank covered(glass canopy or like) or is it open topped. This is an important consideration for all these dissolved gas issues, especially if the canopy is tight fitting.
Post a list of the plants you have in this tank. Interesting, informative discussion you have going here.
Aquaman
Aquaman
Mar 20, 2005
I did see this in the past. Where can I find results now?
I am not saying this is a definitve Ca issue.
I have not seen this in the wild and it would only be definitively identifiable by ash analysis. Even if the element is of low concentration in the wild, it is not a closed system(like an aquarium) and uptake can occur over time.
I agree.
What do you mean here? KH has close relationship with the CO2 and pH and often with the GH which can effect the plants.
I agree this is not the issue here although I am wondering why the need for such a low pH if his test is accurate.
I stand corrected on 24/7 respiration. Submersed gas transport to the substrate is necessary to facilitate some nutrient harvesting processes, most especially iron and perhaps the macro nutrients. Obviously not all plants are the same. In some environments, I am sure that the substrate microbes need the gas exchanges to survive and provide there symbiosis for the plants. In other cases, such as the Madagascar riverine Aponogetons which grow their tubors and extensive roots in course pebble beds, the water flow through the substrate provides all the gases and nutrients needed.
Probably right; is there any data on this.
What is a high fish load?
Don"t underestimate the microbial O2 demand in a dirty or loaded but still flowing cannister or other closed biological filter. A dirty Eheim can be an incredible O2 pump. We ran an experiment with a sealed 125 gallon tank and a dirty 2218 Eheim and took the DO from 7.8 to 2.8 in 90 minutes(YSI meter).
Good discussion, Thanks Tom.
Aquaman
colonel
Nov 25, 2005
118
Thanks for the responses... Aquaman as far as your first post I will do my best to answer some of those questions in hopes of getting this figured out. I should point out first that through the week it is only the GH that has been raising, not the KH. KH always stays pretty much stable. But anyway thats what I have been wondering as far as why it would go up so much? may bad testing? I dont know.... also thats what I would have to think about the PH and KH unless for some other reason the water is being buffered and affecting the PH KH rela. making the chart so far off. I have tested the PH pen against a 7.0 solution many times.... its always right on... and as far as the KH... again maybe bad testing? I dont know KH from water out of my tap has always tested 2.5 or so... give or take .5.... Im not really sure why it is that I need to push my PH so far down to get a high CO2 concentration.... I know for sure that 5.9 seems pretty alright with the fish.... 5.8 stresses them and 5.7 they are at the surface.... ( i only know this from accendantly pushing it to low yesterday :( ) any way I would like to think that I dont need that much CO2 in my tank to grow lush healthy plants.... but then again who knows how much is really in there becuase If it is what the chart suggesnt I would think all animals in the tank would be dead.
I started adding Seachem Eq also.... 1 tsp. at waterchange. I am going to give this a try again... probably keep up with it for 2 or 3 weeks to see if it makes any difference in over all plant health. I would really like to get to the bottom of this and figure out what I can't keep "easy fast growing" plants... looking healthy or growing fast... LoL as far as plants in there I have Alternanthera reineckii, Hygrophila corymbosa - polysperma - and difformis, Myriophyllum simulans, Tonina sp. "Belem", Rotala macrandra - and rotundifolia than some crypts, sword and foreground plants.... the "weedy" plants only grow and inch... maybe two? a week.... and the others like Tonina and Macarnda.... arnt really growing at all... just sort of sitting there. And everything over all just doesnt look so great..... So i am really hoping that will change here and they will start to look better and grow more but who knows. I'll keep an update going and if things dont start to get better in a few weeks.... I dont really know what else could need changed? Maybe try a tear down of the whole thing and start over for one last shot before I give up totally... I dont know.... Hope something gives soon.
Matt
18,696
745
Matt, basically, CO2.
Focus there.
Add some more traces, add a little MgSO4.
Most other things should be fine.
You might consider the mist CO2.
This takes out some of the funny measurements and adds the CO2 directly to the weeds.
Given the KH is 2.5 or so, the plants and the other dosing should be adequate. I get 2" or more a week out of my Tonia.
18,696
745
Aquaman said:
Tom Barr said:
>Jamie already tested this way back many years ago and flourite and a dozen other soils etc>.
Here:
http://home.infinet.net/teban/jamie.htm
It's not true in most cases. Matt does 75% water changes weekly.
Not very closed if 50-75% is flushed and replenished weekly. Then it becomes a rate issue, few plants will use 10ppm or more of Ca++ in a week's time.
Where it is true to large degree: non CO2 planted tanks that recieve no water changes for months, year's even, but even there, I top off with tap water which has Ca++, as well as using things like Onyx sand, which is the best substrate IMO for non CO2 planted tanks, as well as dosing a little SeaChem Eq once a week etc. Some prefer not to do water changes and add CO2, but then they need to reply on dosing and testing.
It's not a need for low pH, rather, a need for CO2, or, remove the CO2 as a limiting factor.
Aquaman
Yes, sounds about right and what I've said combating ADA's/ Amano baloney about plants needing higher levels of O2 at night since they will deplete the O2 out of the water.
It's not the PLANTS are removing the O2, it's the bacteria and fish, just as your test showed fairly clearly.
5ppm loss in 90 minutes is a lot and highly significant, more than fish may do.
the sealed part of the experimental design also showed why it's important to have some surface exchaneg and movement, not to degas CO2, but to allow O2 to come in when it's low in the water.
If excess O2 is degassed after the plants produce a lot, no biggy.
If a little CO2 is lost to degassing, no biggy again, add a tad more.
If you reduce the surface movement down too low, then you will have issues and will need to rely on night time aeration.
It'll work, but Amano's reasons as to why are clearly wrong.
But there is a simpler solution as I've suggested.
Simple is good.
colonel
Nov 25, 2005
118
Thanks for the reply Tom, right now I'm doseing 20 ml of CSM 3x a week should I start adding another 5 or 10 ml to that? Seems like a lot of traces but im open to anything at this point.... just want to get things worked out.
And as far as the MgSO4 I started adding Seachem Eq. at water changes thinking that maybe I needed some more... so Im going to see if that has any affect.... should I not go with the Seachem Eq and use MGSO4 instead? or add some in addition? Also as far as CO2 mist I might give it a try... for right now Im going to stick with what I have, as the gas builds up in my reactor about half way through the day I actually start to get a pretty nice misting effect out of the spray bar that circulates around the whole tank. Anyway I just would like to thank you all very much for your help, and with any luck things will start to straighten out. :)
Matt
PeterGwee
126
Just give the plants a couple of weeks to recover if they are in bad shape or you can just add new ones and see if there is a difference.
Regards
Peter Gwee
18,696
745
If it is Mg, then you will see arather fast response.
Same with CO2.
So.....focus on both if you want tio cure the issue, and you can dabble if you are simply curious to figure out which one does what.
I'm still betting on CO2.
Peter, has the CO2 mist helped you?
I know you have gone around a few times with CO2 yourself:)
We all have.
PeterGwee
126
Tom, the mist has helped alot in the plant growth. I tried using it with the diffuser but it clogs real fast and I get BBA once the CO2 declines. Now, I just use a small powerhead to grind up the CO2 and mist it around the tank which is more stable and consistent.
Tom, I notice that different species of fish seem to have different tolerence to high CO2. My cardinals seems to breathe harder much faster than the harlequin (they seem fine at the level when the cardinals start to breathe harder...rapid mouth movement). So, should I back off or can I continue to add more CO2 since I did get better growth with more CO2 but am concern of the fish health.
Regards
Peter Gwee
18,696
745
I have cardinals, about 50 or so in a 20 gal tank with mist.
No issues.
Tonia, Erio's, HC, R wallichii, macrandra, Eustralis, L cuba etc.
I'm not sure but perhaps a better diffuser stone might help.
If they clog fast, clean often with bleach and place where light does not hit it. I use the sweetwater stones just fine, also, the Azoo diffusers, but seem to have better stability with the SW stones even though they waste a little more but not that much.
SW stones have virtually no back pressure.
PeterGwee
126
Tom, is it possible to post pictures of the tank you mention and possible diagrams of flow patterns that works the best. The diffuser method with spraybar flow doesn't seem to work that great if the tank is pretty packed with stem plants as the flow is retarded before it reaches the other side of the tank. The plants near the spraybar and the center of the tank gets most of the mist whereas the other end has trouble. With the powerhead method, I can get it round good since the flow is stronger due to its single point outlet.
Regards
Peter Gwee
18,696
745
Here's a large tank(350 gal) that uses a spray along the bottom rear of the tank, obviously you cannot see it. There are no less than 1000 fish in this tank at the moment. The Rainbows were replaced with 500 Cardinals.
The CO2 is fed into the return and the spray runs the length in the rear. The flow is directed right out to the front of the tank. You cannot see another 2ft of the tank as it's built into the wall and there is another viewing angle on the other side.
I'll post another large tank I did and Buon's been taking nice care of it:
I'm not sure if you folks have access to this forum here, if not, you may register etc.
http://forum.sfbaaps.com/viewtopic.php?t=339
18,696
745
Here's Buon's tank 4 weeks later after I scaped it(Buon is making me look good!) and also one before from the side. I placed the spray bars vertically as the blow out towards the corn and as to cause a current to flow alonmg the front of the tank where it is open and allows for good mixing.
Note, there is just plain white sand in this tank and EI dosing.
Nothing special, a low light white sand foreground tank, 100gal.
There are two canister filters, Rena filstar 3's and an AM 1000 reactor, I forgot the light watts, it's not that much though but they are PC lights.
For new folks: this tank was covered in BBA, hair algae, and BGA all over the tank and plants when I can there, a thick crust of GSA covered many places, and the tank is acrylic.
But with a little elbow grease, friendly help from everyone in the club, we knocked this out in a about 4-5 hours starting from a complete tear down.
CO2.......it's very important if not the most. Focus as much energy there making sure you are in good shape. Have some surface movement, some ripples are fine.
PeterGwee
126
Thanks Tom for the explanation... :D
Regards
Peter Gwee
colonel
Nov 25, 2005
118
welp I just thought I would post an update on here. Plants have yet to show any improvement, in fact over the past weeks everything seems to have gotten a bit worse, leaves of almost all plants getting holes in them sort of like the middle of the leaves are melting away.
After doing some reading and thinking I decided that it may be due to my substrate, and that I should probably look into giving it a good cleaning. Well needless to say I decided to tackle that tonight I pulled all plants and rocks and was planning on just doing a deep vacum of the entire tank, doing new rock work and putting it all back togeather. Well I have never cleaned the substrate in this tank and apreantly when I set it up a year ago I put a LOT more peat on the bottom that I had thought recently. It seems like there must have been at least an inch maybe more. :eek: Its in baddd shape. So bad I have decided to pull it all wash it throughly and put it back in when its all clean.
None of my plants had very good root structure, pretty much all had weak, brownish roots, some even rotting away in areas where it was really bad. In those areas when i dug down into it, it smelled like swamp mud. Pretty much seems like the entire substrate was sour, with the bottom layey rotting, and the rest of it just filled with mulm. So i am hoping this has been a big part of all the problems I have had with this tank. hope fully in a few days here things will be put back togeather and nice and clean.
18,696
745
Old mucky substrates cause a fair amount of problems.
Good cleaning is a standard thing yearly, you need nothing more than a light dusting of peat and mulm for the bottom of anysubstrate.
I uproot when I replant, many folks strangely don't(at least to me) and top only.
I also re adjust the gravel slopes, terracing etc.
I'm very active on the substrates.
I also used RFUG CPVC filters on most of my tanks for the last 30 years up unitil recently I have now done away with them.
They never got mucky.
I think with good water column dosing, good CO2 etc, things should do well.
