Silica Sand
Discussion in 'Sediment / Substrate' started by inkslinger, Jan 20, 2018.
  1. inkslinger
    inkslinger Guru Class Expert
    Dec 15, 2007
    370
    12:50 PM
    Any one have luck with silica sand? I have got a store that sells #10 and #20 size gravel for like around $10 or $20. for a 50lb bag. pretty cheap to fill a 60x18 , 2 or 3in high.
  2. Christophe
    Christophe Subscriber
    Oct 3, 2013
    395
    257
    12:50 PM
    That's basically what I'm using, 30 grit tan blasting sand. $17 for 100 lbs. Completely inert, just add water... and everything else!
  3. inkslinger
    Dec 15, 2007
    370
    12:50 PM
    where you get yours?
  4. Christophe
    Oct 3, 2013
    395
    257
    12:50 PM
    Lowe's -- a huge hardware/lumber/construction supply joint.
  5. Allwissend
    Allwissend Article Editor
    Jun 20, 2016
    462
    266
    1:50 PM
    Sand works and has worked for many decades now. Just keep in mind that column fertilization is needed as nothing is in the substrate. If it is "good quality", it should not be dusty at all. However, in time even this substrate will be enriched by detritus.
