Shrimp And Trace Elements
Discussion in 'Inverts' started by azappetti, May 31, 2018.
  1. azappetti
    azappetti New Member
    Dec 3, 2017
    9:12 PM
    Hola:
    When adding trace elements, what is the maximum dose of Cu and Fe, to avoid the toxisity of shrimps?
    Gracias
  2. Allwissend
    Allwissend Article Editor
    Jun 20, 2016
    462
    266
    1:12 AM
    You're not gonna like this but ... depends.
    It depends on 3 things
    1. uptake (plant, microbial )
    2. precipitation (precipitated Cu will not be toxic anymore)
    3. organics and chelators (they often make metals less toxic)
    So adding a single dose of 0.07 mg/L Cu once a week is not the same as adding 0.01mg/L Cu 7 times a week. I had one aquarium with breeding RCS where I was adding 0.01mg/L Cu daily and I did not notice any problems but the tank was high light with a very high plant density. It was overkill when you compare the Thrive+ weekly dose of 0.0126. But you can make an idea...
    Regarding iron, I would not worry about it, you can offer the plants all they need (0.5-1mg/L Fe) and not be toxic towards most shrimps.
    PS. All of the above is with 50% weekly water changes and routine cleaning of the substrate.
    KeeperOfASilentWorld likes this.
