dear all,
I visited yesterday a somebody who is smart enough to make calculations about the strength of my floor and it appears that I can place a larger tank.
Now, I want your help with the design/setup
I have 3 questions/problems:
-light
-substrate
-CO2
To begin with the light.
-I want to use 80 watt TL5 with a dim option. The size of 80 watt TL5 with caps is 149 cm. The tank itself will than have a length of 155 cm. because I will use 1 cm glass, the space inside the tank will be 153 cm. Does this sounds oke?
-The tank will be 155x50x50= 387 liter=102 gallon. I think I will need 3 watts/gallon: 3x102= 306 watt. Thus I need 4x80 watt TL5. Oke? (It will be an EI based, high CO2 tank).
substrate
-also a problem. The ADA stuff is simply too expensive considering the fact that you need to change it once a year/2 years. Because the ADA AS is not available in the Netherlands, I need to import it from England: shipping costs 75-100 british pounds! I am willing to pay it, but only for a one time occasion (once in 10 year or so). So I looked further and decided that I liked seachem onyx sand. (is it in real live pretty as well?). My plan is now to buy onyx sand and place difficult plants in a bucket of ADA AS. Good plan?
If yes, what are the amounts I need for this tank? I estimated 8 bags of onyx sand (56 kilo). And if ADA AS can be stored after opening the bag, I will order 1x 9 liter bag.
CO2:
-always a problem . The setup I want is like this: 2x powerheads connected with a CO2 tube/venturi and an external CO2 reactor. To get this setup I need a 3-way splitter. I have seen that I can buy it from aquatic magic. Sounds good to me. On that same site however, there were a number of interesting looking CO2 diffusors like the rhinox 5000. Is this (or a similar product) worthwhile buying or should I stick to the powerheads?
The external reactor: I now have a dupla S reactor. I think it will be too small for this tank. So I will have to buy a new one. What do you recommend? I have seen the largest CO2 reactor from aquamedic. Is this oke?
thanks in advance!
yme
-light
-substrate
-CO2
substrate
CO2:
thanks in advance!
yme
