Hi Tom,
I know when we setup the c02 atomizer that we found the single bubble rate point first.
We then connected the c02 to the atomizer. At that point you started turning the vernier handle OPEN and counting.
Were you counting FULL turns of the valve or increments of 1 on the vernier markings? I missed that UOM....
I know you set the PSI to 10-15 or so and I know many folks with atomizers go for higher...
Any thoughts to share on the initial setting of the rate?
Obviously only time and plant health will tell if set correctly
I expect to adjust over the next several weeks....monitoring is constant...will be easier for now with no critters so I can crank it up as I like/need...
