Seachem vs ADA
[email protected]
May 11, 2005
64
Italy
Hi Tom,
I have a 200lt (about 50gal) tank, I have for substrate the Ada Power Sand and Ada Aqua Soil.
I like to try the Seachem products; what do you think about substrate ADA and Seachem chemical producys ??
Giancarlo Fimiani ..... from Italy (sorry for my bad english)
baruch mor
30
Re: Seachem vs ADA
both products are great . i preffer the ada more then the seachem though
Re: Seachem vs ADA
A few things come into play.
Cost is the largest.
Flourite might be far more there than ADA.
Over all, flourite is fairly inert, it has plenty of Ca and Fe.
It weights more, making planting easier.
Onyx has more Ca/Mg, and is finer grain, like sand.
I add mulm and peat or leonardite to these two substrates.
ADA is a 2 layer mix, these invariably mix over time. Power Sand has macro nutrients, NH4 etc in it. The Aqua soils are like Flora base, 1/2 baked clay.
These are much lighter than Onyx/flourite and crumble in your hand.
They will turn mushy over time, but some light vacuuming like you do to remove mulm will address that.
Powersand loses it's nutrients after a couple of months so both flourite and powersand are onm equal terms there.
Some folks do not move their plants around or rearrange every so often, most folks do, some are careful when they do move things/replant, some are not.
You can add things to any substrate to add nutrients/peat/mulm etc.
I just know I end up mixing anything with 2 layers, and having it look tacky after I replant a tank or redo it after a 1-2 or more years, decide on a different scape etc etc.
Peat & mulm do not matter there.
Both grow plants well and both depend heavily on the water column later.
[email protected]
May 11, 2005
64
Italy
Re: Seachem vs ADA
Thanks Tom
I decide for ADA Power Sand + ADA Aqua Soil Africana.
I look that the PH and GH/KH values decrease very much. For how many days the GH/KH decrease ??
Can I add for many days chemical products for increase KH/GH ??
Giancarlo
Re: Seachem vs ADA
I'd just do water changes for awhile, the lowering of the pH/GH/Kh is from peat/soil based organic carbon. That will wear out after about 1-2 months.
Large water changes will make things stable.
srozell
110
Re: Seachem vs ADA
How do you Add peat or leonardite to the substrates? Mix it it, or bury it with the Onyx sand?
What are the advantages/disadvantages of peat over leonardite?
Re: Seachem vs ADA
You mix in the bottom 1/2" layer.
Peat can be messy if pulled up, leonardite last longer but works slower and is dark grey like Onyx and is heavier. Peat is cheap and easy to get.
srozell
110
Re: Seachem vs ADA
So the bottom half of the substrate would be 50% peat and 50% onyx, and the top half would be 100% onyx?
Laith
182
Geneva, Switzerland
Re: Seachem vs ADA
From what I understand, you need very little peat. A 1/4" layer (half of 50/50 1/2" mix) would be alot of peat.
I haven't used peat yet but will in my next tank. The amounts I've always heard was to just sprinkle some on the bottom glass but not enough to completely cover it...
[email protected]
May 11, 2005
64
Italy
Re: Seachem vs ADA
Hi Tom,
when do you think, abuot start the fertilizer program (with Seachem products).
I have start the tank about 10 days ago, we are put after 2 days the plants (fast growt and slow growt).
What do you think about quantities of Seachem products ??
Thank
Best regards
Giancarlo
