Seachem Equilibrium w/KH2PO4
PeterGwee
126
Tom, since you recommend dosing macros/micros seperately due to potential of Fe precipitating out of solution, does Equilibrium pose an issue as well when dose together with macros?
Regards
Peter Gwee
Re: Seachem Equilibrium w/KH2PO4
CaSO4 and FeSO4 is present in there also.
PO4 can preciptate with both.
You can dose PO4 seperately and add traces with the other things(KNO3 etc).
I do not think you will get away from some peciptation but you can reduce it some.It's not something that will make or break a tank though either.
