Salty Life Is Over, Time To Get Fresh.
Discussion in 'Introductions' started by NRS4LIF, Aug 11, 2019.
  1. NRS4LIF
    NRS4LIF New Member
    Aug 11, 2019
    8:03 PM
    As the title indicates, I am officially hanging my saltwater hat and trying on the freshwater one. Saltwater was fun for many years but it was time to leave. One of the biggest reasons why I am switching is because of the animals we keep. Corals are easy to kill and the damage to the environment through coral/fish collection is not something I can support. I know freshwater has its own host of issues but I feel it is by far the lesser of the 2 evils. I want to have an aquarium, and being a good steward to the environment and the animals I keep has moved to the top of the list. I have invested ridiculous amounts of money in aquariums and equipment so I am repurposing as much of it as I can. All saltwater live stock has gone to good homes, all aquariums have been drain and refilled/cleaned with vinegar and water. All deposits have been removed from tanks and equipment. The first aquarium I will start with is a Red Sea Reefer 525XL, it has a 108 gallon display (59x22x22) and a 31 gallon sump . I am choosing to start with this aquarium because of the volume. I am hoping the added volume will give me more stabile parameters and less dramatic swings as I learn freshwater. Some of the equipment may be overkill but it can be adjusted down.
    Lights
    Hydra 26HD x3
    • 6 - Cree XP-G2 Cool White (> 70 CRI)
    • 6 - Cree XT-E Royal Blue
    • 6 - Cree XP-E2 Blue
    • 2 - OSRAM OSLON Deep Red
    • 2 - Cree XP-E2 Green
    • 2 - SemiLED 415nm
    • 2 - SemiLED 400nm
    Each LED is adjustable so the range is 5000K to 20,000K. I am going to shoot for 6500K-7000K. I have been using the Apogee 520 to measure PAR and I can easily hit 150 (7000K) at the bottom of the aquarium 21 inches deep & no substrate yet. I wish I had a way to measure the PUR but I do not. If I can't find a way to get these lights to work, I will sell and reinvest but I need to at least try.
    Pumps
    Ecotech Vectra M1
    • Pump Type: Centrifugal / DC
    • Flow: 2000 gph (7500 lph)
    • Pressure: 21.5' (6.5m)
    Ecotech MP40wQD x2 (inside aquarium)
    • Flow: 4,500+ gph (17,000+ lph)
    • Communicates wirelessly with each other to create different currents
    The pumps will be reduced significantly. Need to aquascape first.
    Reactors
    AquaMaxx XL x2
    I plumbed these inline and can run multiple medias simultaneously if needed
    Heater
    Ehiem 300w heater
    Dosing
    Bubble Magus w/ extension. No idea of dosing regiment yet but equipment is available should i need it
    Controller
    Apex Jr will control and monitor pH, temp, and CO2 (5lb tank w/ regulator that came off calcium reactor).
    Aquascaping
    Manzanita wood, Seiryu stone, Eco-Complete in areas where column feeders will be and ADA Amazonia in places where substrate nutrients are required. Plants TBD and layout is currently WIP.
    Anyone that has any recommendations and/or can share their experience switching from salt to fresh is totally welcome. I appreciate feedback. Today everything was filled with freshwater, checking plumping for leaks and all equipment being tested after dismantling.
  2. Fish Out of H2O
    Fish Out of H2O New Member
    Jun 3, 2018
    21
    6
    10:03 PM
    Great write up and planning on your system. I’m not the most experienced, but one thing stands out. I installed seiryu stone in a tank a while back and then learned they are not inert and may raise GH and KH. I quickly removed and switched out to granite. May be worth some additional investigation to ensure it works for your water, plants and fish.
  3. Devisissy
    Devisissy New Member
    Oct 21, 2019
    10
    8:03 PM
    There are a group of us that are the only owners of certain coral species left as they are extinct in the wild. The coral has been fragged and passed around and continues to be passed around so that in case it fails in one tank it still has a chance, with the ultimate goal of putting it back into the reefs. Also, only collecting aqua cultured specimens and so on. There are many ways to be conscientious of the environmental impact, also help with awareness and species health, and still have a beautiful tank. Don't even get me started on fresh. Many species are invasive and even just flushing one spore or stem can have detrimental effects on local flora and fauna. Also, some of the collection practices for freshwater fishes is just as bad as collection for salt. However there is a database being made with tissue cultures so that is an excellent thing. So no it's not the lesser of two evils just different. Side note, 20 years in reef, 10 seriously with planted, planted is WAY harder. Also, you are going to want the planted version of that hydra, they are 25% off on BRS right now!
    Kevin Chan likes this.
  4. ScubaSteve13
    ScubaSteve13 New Member
    Mar 28, 2020
    11:03 PM
    Good Luck! Looking forward to seeing your new scape/progress.
  5. JeremyDMeyer76
    JeremyDMeyer76 New Member
    Oct 12, 2018
    10:03 PM
    I did mostly SPS dominated reef tanks for 15+ years before getting into the planted tank hobby.
    Not going to lie, so far it's been a struggle but I dont miss the salty hard corrosive water.
    Sent from my SM-G955U1 using Tapatalk
