Runing filters in series
Discussion in 'Talk to Tom Barr' started by feh, May 18, 2011.
  1. feh
    feh Guru Class Expert
    Jan 14, 2011
    668
    9:59 PM
    What are the benefits and drawbacks to running filters in series?
  2. Tom Barr
    18,648
    557
    9:59 PM
    Less flow, more clogging.
    You get better flow and less clogging running them independent.
  3. feh
    Jan 14, 2011
    668
    9:59 PM
    So basically no real benefits?
  4. Gerryd
    Gerryd Plant Guru Team
    Sep 23, 2007
    9:59 PM
    I disagree that there are no real benefits. Filters in series will affect performance as they clog. If the first filter clogs, it affects all downstream components.
    If in parallel, the flow from the clogged filter will swap over to the unclogged one if setup that way.
    Even if not, the clogging of one filter will not impact the other if in parallel.
    BIG difference.
  5. feh
    Jan 14, 2011
    668
    9:59 PM
    I meant no real benefits of running them in series rather than in parallel. :)
  6. Cyclesafe
    Cyclesafe Guru Class Expert
    Jan 19, 2011
    136
    9:59 PM
    I ran an Eheim 2128 then a 2229 in series for several years. When I switched to running parallel, flow improved and there was no increase in detritis in the 2229. So, I'd agree that having filters in series gains nothing. Flow is more important in planted tanks than what was once thought. Not such a CO2 loss penalty.
    #6 Cyclesafe, May 18, 2011
  7. Tom Barr
    18,648
    557
    9:59 PM
    If you are in staged micron filtration.........then perhaps.........
    Otherwise, I see little benefit.
  8. feh
    Jan 14, 2011
    668
    9:59 PM
    That makes sense.
