Rotala Sunset And Florida Leaves Drooping
Discussion in 'General Plant Topics' started by Lazy999, Sep 22, 2018.
  1. Lazy999
    Lazy999 New Member
    Aug 5, 2018
    1:23 PM
    Hiii everyone,
    Any chance to save the plants? My sunset and florida leaves start drooping
  2. burr740
    burr740 Micros Spiller
    Staff Member Moderator
    Feb 16, 2015
    1,398
    1,293
    12:23 AM
    aka The Dreaded Droop and Die
    It's a thing and those stems are toast. There's no coming back if one ever starts doing that. Doesnt matter what you do.
    Ive never seen anyone explain the direct cause. There may not be only one cause, it might be just what happens when this species (or genus?) becomes unhappy.
    Ive seen it happen with high nutrients and low nutrients, inert sub and rich. Ive also grown them fantastically under all these conditions.
    Personally Ive wondered if temperature plays a role. Once when it happened to me with Sunsets they'd been growing ganbusters for several months, then around July they slowly started dropping. The only thing that changed is summertime hit and tank temps went up a 2-3 degrees. No idea if that's what caused it or not.
    Maybe @Pikez or @rajkm can shed some light. I'd be interested in anyone else's experiences or thoughts
    Greggz likes this.
  3. Lazy999
    Lazy999 New Member
    Aug 5, 2018
    1:23 PM
    Gosh... there goes my one and only sunset stem... =(
  4. Greggz
    Greggz Lifetime Members
    Jan 6, 2016
    448
    574
    6:23 AM
    Yeah as Burr said, droop and die syndrome.
    I had some going really well for quite a while. Propagating and had a nice big batch.
    Then it seemed like about two or three at a time would droop and die, and a couple months later they were all gone.
    Sure was a beautiful bunch at it's a peak. But when it doesn't like something (who knows what??????????????) there is no saving it.
  5. Pikez
    Pikez Rotala Killer!
    May 12, 2013
    1,962
    1,465
    6:23 AM
    Oh yea, those stems are toast.
    I'm the court-appointed Poindexter on these plants and even I don't have a clue on what causes this.
    We have a rough idea on other Rotalas but not these two. Them're odd ducks.
    Greggz likes this.
  6. Pikez
    May 12, 2013
    1,962
    1,465
    6:23 AM
    Generally, these plants seem to do better in harder water with elevated GH. For me, they go either way, but they hang on a LOT longer in hard water and inert substrate. Nutrient level does not seem to matter as Burr indicated.
  7. Lazy999
    Lazy999 New Member
    Aug 5, 2018
    1:23 PM
    Ahhh i see. Tx for the advise both of you.
    Guess either they like your tank or dislike it.
  8. rajkm
    rajkm Article Editor
    Sep 16, 2015
    670
    216
    6:23 AM
    I will add on to burr and pikez that yes, the droop is usually unhappy plant and most likely recovery chance is quite less.
    I have had some stems droop while a good amount is doing well, the stem will darken and will rot away from bottom.
    You have some flat leaf coming up but the stem suffocates itself from the bottom and then it’s lost cause.
    Also many have come to a conclusion that sunsets don’t do well in soil. I wish to prove them wrong but haven’t succeeded yet.
Tags:
