I've seen it do this under high light. I've also seen it not do it under even higher light. I'm not sure if light is the main factor to be honest. It grew straight up in the highest light tank I've ever run. Its crept along the substrate in a 55 gallon with less light. Not every stem did it though, it was the odd one or two that would. Maybe low nodes start to root and then take off horizontal.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
