Root Tabs And Algae!
Discussion in 'Advanced Strategies and Fertilization' started by Neil, Oct 15, 2018.
  1. Neil
    Neil Member
    Oct 15, 2018
    30
    7:14 AM
    I'm using ADA substrate ..its an year old.
    It has started giving early signs of exhaustion, I'm planning to feed the plants with Substrate Tabs.
    The water I'm using is very hard & it is groundwater.
    Fairly high in Phosphate, Nitrate and Fluoride.
    Would it be a good idea to start using Root Tabs without worrying about Algae ?, I've bushy plants in my tank btw
  2. skija
    skija Lifetime Members
    Nov 16, 2015
    352
    83
    2:44 AM
    I'm using ADA iron bottom each 3-4 months under staurogyne and rotala
    No signs of algae , staourogyne likes iron
    Neil likes this.
  3. Neil
    Neil Member
    Oct 15, 2018
    30
    7:14 AM
    Thanks for the reply Sir...!! ;)
  4. echocinco
    echocinco New Member
    Sep 19, 2018
    25
    6
    6:44 PM
    You can also use the Laguna plant spikes and make sure they are fully buried in the substrate. I'd any of it is exposed or is too shallow though, you might get an algae bloom (assuming your plants cant keep up w the nutrients).
    When the spikes run out, you can refill them with osmocot also.
    Sent from my SM-G950U1 using Tapatalk
