This is an excerpt from a Journal Yang et al, 2008 (in Aquatic Botany) on Milfoil grown is infertile sediment and fertile sediment. But if you think about it, the plants should try and look for more nutrients under limiting conditions vs not. They did not add water column ferts, unfortunately and looked at that as well like Cedergreen and Madsen(2001).
"Higher sediment nutrient availability resulted in larger plants. Relatively more biomass was previously shown to be allocated to roots versus shoots depending upon which resource was more limiting (Cronin and Lodge, 2003 G. Cronin and D.M. Lodge, Effects of light and nutrient availability on the growth, allocation, carbon/nitrogen balance, phenolic chemistry, and resistance to herbivory of two freshwater macrophytes, Oecologia 137 (2003), pp. 32–41. Full Text via CrossRef | View Record in Scopus | Cited By in Scopus (24)Cronin and Lodge, 2003). When sediment nutrients were more limiting, M. spicatum allocated more resources to the growth of roots, resulting in a higher RWR and RSR. This is consistent with allocation patterns observed in most herbaceous terrestrial plants and other aquatic macrophytes ([Barko and Smart, 1986] and [Wilson, 1988]).
So with many species, we might expect to see larger root biomass/growth rates totals with sand and light water column ferts and less with ADA AS or mud.
We found this to be true as well in our dry weight comparisons at the lab.
Overall, total biomass was much higher, significantly different with the fertile sediments without any additions to the water column, obvious there as well, they had plenty of nutrients while the other non fertilize sediment plants had no nutrients, they they looked for nutrients in the sediments.
Perhaps.......larger roots are not really an indicator that the sediment is more fertile, this has been an assumption of many, particularly the Sword and Crypt folks..........
Lots of evidence suggests otherwise.
the paper is mostly looking at how fertility and autofragmenting are related.
As you might guess, when the nutrients become strongly limiting, the plants break apart and pieces hopefully will land somewhere there are nutrients in the sediment and/or water column.
I've seen this is many cases growing this same species out side in pots in 400 Gallon vats for various experiments. If you do not add ferts when the tanks are full of healthy growing plants, in a few days that just break up into pieces.
Sort of analogous to Caulerpa melting when the NO3 crashes in marine Refugiums.
