rio needle wheel impellers
Left C
Sep 26, 2005
2,500
73
Burlington, NC
There are two different fractioning impellers shown on Rio/TAAM's site for the Rio+ 1100, plus a kit to install the optional needle wheel impeller. You can order from Rio/TAAM: http://www.riopump.net/products_pumps/rioplus_parts.html
Rio Plus IM1100 Rio Plus 1100 Impeller Assembly Kit UPC # 0006760 0586 6
Then there is a kit that uses a needle wheel impeller for finer bubble for the 1100:
Rio Plus needle wheel impeller conversion kit 1100-1400 UPC # 0006760 1407 3
The needle wheel impeller itself is:
Rio Plus needle wheel impeller 1400 UPC # 0006760 0854 9
No, in the USA there are no vendors that sell Rio 1000 needle wheel impellers.
You must contact Taam directly in CA, USA and they will sell you some.
Buy the pump elsewhere, few folks will need anything over a Rio 1000.
Best to call Taam and place the order that way vs on line.
samh
Nov 16, 2010
193
SE QLD Australia
yeah i've already got a 1100 which i modded the impeller but just wanting finer bubbles, can you use coarse filter pad mesh to chop bobbles more finely?
samh
Nov 16, 2010
193
SE QLD Australia
Left C;68035 said:
I'm not having very much luck finding vendors, hence ebay. Below is some type of needle wheel for the 1100 and below it is the stock one.
http://cgi.ebay.com/TAAM-RIO-FILTER...249?pt=LH_DefaultDomain_0&hash=item2a07871b21
stock: http://cgi.ebay.com/Replacement-Imp...318?pt=LH_DefaultDomain_0&hash=item4a9aa54916
Btw thanks for finding that for me, i'm not sure that needle wheel impeller will do much different to the chopped blades, i think that pinwheel looks like a go-er.
Sam
Left C
Sep 26, 2005
2,500
73
Burlington, NC
I hope that it works out for you.
Do you think that you will need that kit above to use it or can you just swap out yours?
The Rio 1000 is plenty big enough for most folks' tanks, if you have 300-400 gal, then 2 of them this size is a good idea.
Very quiet, I do not notice it. I also do not see any mist etc.
All the tank pics you see of my 180 gal has the CO2 mist going.
Taam Rio will sell folks what they need here in the USA, not sure about in EU or AU etc.
