Is a Rio Plus 1000 with a needle wheel impeller used for CO2 circulation overkill for an 80 gal tank? It will be in a W/D sump and the output will be fed into the return pump. If an intake venturi is added, can the CO2 line be attached to the venturi tube port as the way to feed the CO2 into the pump?
