Rexolin APN & Calculator confusion
Discussion in 'Estimative Index' started by FastFreddy, Oct 27, 2012.
  1. FastFreddy
    FastFreddy Junior Poster
    Aug 27, 2010
    29
    12:43 AM
    I've recently switched from using Flourish to Rexolin APN for my trace nutrients. I'm having some difficulty calculating how much to use. In Tom's article it states that for aquariums from 40-60 gallon, 1/8 tsp+/- is sufficient. However, when I put that amount into this calculator for my 45 gallon tank it says it will only give me 0.15ppm Fe. This seems to be too low. Please let me know how much I should in fact be dosing. I'm otherwise dosing EI. My tank has pressurized co2 and 2x39w T5 bulbs and measures 36x16x18. It is densely planted with various fast growing stem plants. Thanks in advance.
Similar Threads - Rexolin APN Calculator
  1. Mxett
    640
  2. cazandchris
    381
