Resin in Canister Filter
lightyear
Sep 24, 2010
52
Hello,
I've seen a filter media for canister filter that says "resin filter". It looks like a bioballs but claims to remove organic waste, etc. ever heard of resin filter before? does it work?
Yes... Apparently...
Works kind of like water softeners, ion exchange, I have only seem them at a LFS, they say it works, I do not see any reason it shouldn't. :)
I do not know that it is any better than Purigen or activated charcoal or any other stuff... :cool:
lightyear
Sep 24, 2010
52
you think its safe in planted tank and will help crystal clear water? or better off buying purigen for me, the stuff is cheaper, if it does the same thing might get this.
Cheap & Easy
The resin is probably safe enough, I have seen them operating in a fish store. :rolleyes:
I tend to think it is a bit of a scam, :p but some folks think me a cheapskate, :eek: primarily spouse, mother-in-law, kids, employees, lawyers, accountants and pretty much anyone that have ever met me... :eek:
I would go with Purigen.
lightyear
Sep 24, 2010
52
thanks for input. in contrary to me I avoid overrated product filled with marketing talks thats though I'm willing to pay for premium price once proven. i'll check purigen then, did it reaaly made your tank crystal clear?
And You Can Recharge It...
Yes, it does make ths water crystal clear. Purigen is one of those outstanding products that delivers on the claims. :cool:
I do not use Purigen or Chem-Pure or activated charcoal or diatomaceous earth or micron filters all the time. :):)
hbosman;56755 said:
Does Purigen remove nitrates or any other nutrients?
Not significantly. Likely the best choice and over time, more economical than Carbon for most folks.
The Time Has Come To Speak of Many Things: Of Shoes--& Ships--& Salts-- & Organics
Hi All,
This is interesting to me and I think it is where a lot of the nonsense regarding fertilizers in aquariums comes in. :confused:
Activated carbon, Purigen and so forth remove “organic” material. Organic nitrates and phosphates and so forth act differently then the salts. :confused:
Activated carbon and Purigen remove organic nitrates and phosphates, but these “organics” appear, to me anyway to be bad actors. So in a tank with a lot of organic compounds hanging around the level of Nitrates are reduced by the use of Purigen and so forth. :)
The salts we typically dose are not affected at all by Purigen.
I do not understand this other than to state the obvious, by definition to be “organic” the compound must include carbon. :rolleyes: Further and equally obvious the electrical make-up and the interfacial pressures and behavior of “organic compounds compared to “salts” are different. :rolleyes:
Somewhere in all of this comes the reason one group of honest and reasonably diligent folks can find, for instance, a level of Nitrates that appear to be toxic while another sees no problem with many times the level. :confused:
Always been curious about this. :)
Perhaps another thread... :eek:
hbosman
Oct 22, 2008
277
Leesburg VA USA
Very interesting! I would like to hear more why it works more on organics vs. salts. Since Purigen seems to be endorsed here, I think I have to give it a try.
James121
Oct 14, 2010
I have a resun canister 808 model 1600l/hr.
It seems to do the job so far and i've had it running for 2 yrs and has'nt skip a beat yet. It gets a little noisy when the media begins to clog up,but it gives me an indication that it's time for cleaning.
I'm not sure about the current line up in the resun range,but i guess it pays to do a little research before taking the plunge. Incidently my mate is on the hunt for a cannister w/ uv also.
