Remineralizing RO with tap, more trace needed?
Discussion in 'Aquatic Plant Fertilization' started by Hachi, Aug 25, 2016.
  1. Hachi
    Hachi Junior Poster
    Aug 25, 2016
    3:23 PM
    Hello! I've been remineralizing my RO water with some tap. Is this sufficient for plants or should I be adding extra trace elements through something like Plantex? Thanks!
  2. Pikez
    Pikez Rotala Killer!
    Staff Member Moderator
    May 12, 2013
    1,962
    1,473
    3:23 PM
    You need to add some Calcium and Magnesium salts for GH general hardness. Usually sulfate. Occasionally chlorides. Maybe add some carbonate/bicarbonate for some KH hardness.
    [Nitrate, phosphate, and potassium] = macros. Macros and traces should be dosed on alternate days. Best to add small doses of traces a few times during the week between water changes than all at once like you would with GH.
  3. Hachi
    Hachi Junior Poster
    Aug 25, 2016
    3:23 PM
    Thanks! My tap water starts out very very hard, which is why I've been using RO with some tap. After mixing the two I end up with a GH of about 4. Just wasn't sure if that was enough for most plants, or if I needed extra traces on top of it.
