Hi
This is my first time posting on this forum as I have a reef tank and have never kept a planted or freshwater aquarium, but I've been reading this section of the forum for a few of weeks now and decided to post here rather than a saltwater forum because in all honesty you guys are definitely the subject matter experts when it comes to CO2 setups. Before I begin I'm a UK aquarist so a lot of things you Americans can easily obtain we struggle to aquaire here in blighty! I'm about to begin putting together a calcium reactor as I'm sick and tired of battling the constant build up of chlorides that result from the heavy use of dosing two part calcium and alkalinity supplements! From reading freshwater forums I understand that a quality dual stage CO2 regulator is the best route to go and Burkert solenoids are rock solid, but I'm confused from this point on! I think I've found a decent regulator, it's a "BOC 8500 Series CO2 0-2 bar/0-30 (41490)" here's a link referencing which regulator it is (I'm not purchasing it from this site however)
http://www.fnpile.co.uk/index.php?area=products&product_id=1991
It appears to be well built and states that it's dual stage and the outlet for this regulator is 3/8" RH (does RH mean Right Angled?), is the 3/8" RH outlet the point at which a solenoid valve would connect directly to the regulator or can a solenoid valve even be directly connected to this type regulator in the first place? I've also found an online UK source for stainless steel Burkert solenoid valves but cannot find one that will fit the 3/8" RH outlet on the regulator, but I've read somewhere that regulator outlets can be removed and a 1/8" sized outlet could be screwed in it's place is this true, if not can anybody recommend me a reliable solenoid valve with a 3/8" connection? I apologise if these questions are simple to answer for you guys but most reef keepers who run calcium reactors utilise crappy, off the shelf aquatic regulators and needle valves and any quality guides that I can find that don't use standard off the shelf regulators are written by Americans with American regulators which use different connections to the UK NPT ones?
I admire the expertise on this site and appreciate any advise offered
Many thanks
Many thanks
